Jasper
posted on 3/8/02 at 07:39 PM |
Cortina axel question
I'm starting to assemble the rear suspension and have discovered the Cortina axel has an offset prop. I presume I just make the tranny tunnel to fit,
loosing a bit of the drivers side area? Or was it just an optical illusion??
posted on 4/8/02 at 07:22 PM |
I found the same with the capri axle. The diff is central but the nose is offset to the driver side. I made the tunnel slightly offset to that side
for about the last 150mm and the prop clears by 15mmish. I used fibreglass seats from MK and they fit in so I didn't lose much space. ___/ A bit like
that but not as exaggerated.
Pete.
