Author: Subject: Steering Extension
Daddylonglegs
posted on 28/5/09 at 05:11 PM Reply With Quote
Steering Extension
I have sourced what I think I need to connect the sierra column (adjustable) to the mk2 escort rack. Apparently it is around 3" long. Does this sound correct? I know it needs the triangle clamp at one end but not sure about the other.
I also have a surplus escort steering column which I intend to use to connect the extension to the escort steering rack coupling.
JB
Flamez
posted on 28/5/09 at 05:26 PM Reply With Quote
Triangle one end, splined shaft the other
my build mac1motorsports
Daddylonglegs
posted on 28/5/09 at 05:36 PM Reply With Quote
Apparently that's what this has got, it's just that I thought that it was much longer than 3"?
JB
handyandy
posted on 28/5/09 at 05:39 PM Reply With Quote
i,m trying to work out how you are setting the column up,
on mine at the rack end is a (think its called Group 4 coupling) then i have bought a shaft from RD that has a spline at either end, this then gets cut in half approx & welded to the part that has the triangulated coupling which then attaches to the triangle shaft up into the column shroud, thats how i think it all goes together more or less, i have the parts but have not made it to size yet.
andy
blakep82
posted on 28/5/09 at 05:50 PM Reply With Quote
3' maybe? as in 3ft?
________________________
stevegough
my luego velocity is looking like it is going to need an extension about 13" long - sierra column to escort II rack.
I don't know if this is any help to you?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Daddylonglegs
posted on 28/5/09 at 09:11 PM Reply With Quote
I'm not sure what to think. I seem to remember seeing a photo of a coupling on here somewhere that looked quite short. Maybe it's just a UJ type coupling that he is selling? I'll see if he can send a picture of it and then I'll post it on here. My intention was to fit the joint to the column and then use the escort steering column shaft I have spare as the extension piece between it and the joint connected to the steering rack shaft.
Thoughts please?
JB
robinj66
posted on 28/5/09 at 09:41 PM Reply With Quote
I think you want something like these - the length will obviouslydepend on your installation
[img][/img]
[img][/img]
[img][/img]
Daddylonglegs
posted on 29/5/09 at 07:13 AM Reply With Quote
Not a very good picture but I'm wondering if this is what he is selling?
Image deleted by owner
I've asked for a photo but not holding my breath.
JB
posted on 29/5/09 at 07:49 AM Reply With Quote
That looks like the UJ from a KA steering column. If so it's no good to you since it doesn't use the triangular shaft.
Daddylonglegs
posted on 29/5/09 at 08:41 AM Reply With Quote
Ooops!
Wrong piccy
JB
