Author: Subject: Handbrake compensator - opinions please
Dangle_kt
posted on 30/5/09 at 12:30 PM Reply With Quote
Hi Folks,
Another of my sva fails was the fact the handbrake wasn't compensated.
I run an english axle, with escort handbrake cables. The current set up is just a flat plate the when the handbrake is pulled, it pulls the cables.
The problem the tester said, is if one of the cables stretches or is out slightly, that one wheel will have more braking force than the other - and there needs to be a compensator.
Now as far as I can find, there isn't such a thing on the old escort (though I'd love to be proved wrong!!) so I have designed the following, that I will make from box.
handbrake compensator
The cylinders out of the near edge is meant to be the cables (which will slide in through slits (which I didn't put on the model)
The idea is the angled peice will be attached to the bolt which comes off the handbrake lever, and this will be attached via a bolt as a pivot to the rear box section, that can pivot due to the differing tension on the cables (if there is any misadjustament or strecthing)
What do you guys think? Will it work?
Dangle_kt
posted on 30/5/09 at 12:36 PM Reply With Quote
for context this is the current setup (well near enough)
posted on 30/5/09 at 12:43 PM Reply With Quote
Made mine out of a piece of 1" angle iron, cables are Allegro and lever is shortened Sierra with the short connecting cable. Looking at yours it needs to pivot freely around the rod from the handbrake lever and perhaps be a bit wider at the point the cables attach. No need for over engineering unless of course you want to .
Dangle_kt
posted on 30/5/09 at 12:49 PM Reply With Quote
thanks for the reply. How would you get it to "pivot freely"?
I dont want to over engineer stuff, but I can't get my head round an easy way to fix it!
posted on 30/5/09 at 12:57 PM Reply With Quote
Escort handbrake cables?
Escort used a single cable
However there isn't that much wrong with your current setup -- replace the bolt with a rose joint and use a bit of angle instead of flat plate you will meet his criteria BUT I can see another danger that the cable ends can slip out of the plate especially if one cable fails --- you really should add some effective method of locking the cable ends in the slots.
MikeR
posted on 30/5/09 at 12:58 PM Reply With Quote
bit of round tube, hole in it size of hand brake threaded section, fit that before the bolt so the bar pushed / pulls against that (and make the hole in the bar bigger).
that should do it shouldn't it?
If space is an issue, cut the tube in half so its only 180 degrees bend not full 360 round tube.
Dangle_kt
posted on 30/5/09 at 01:14 PM Reply With Quote
sorry maybe I didn;t make it clear enough, that was a first mock up - the current item has nuts to stop the cables slipping out.
The idea of using half of a tube is a good one! thanks.
I'll muse some more.
posted on 30/5/09 at 01:36 PM Reply With Quote
I used a Sierra handbrake lever that has a short cable attached to it with an "eye" on the end to which I attached the angle iron using a short clevis pin. Allows plenty of articulation
stevegough
posted on 30/5/09 at 02:30 PM Reply With Quote
this is the pic of how luego say to do it - taken from the manual.
sorry - see next post for pic.
[Edited on 30/5/09 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
posted on 30/5/09 at 02:37 PM Reply With Quote
Luego Locost C20XE.
