Author: Subject: 2ltr non efi ecu module wireing
rich201283
posted on 6/3/04 at 10:15 PM Reply With Quote
Ive got the big ali box and got the 3pins on the dizzy, i think it has a stepper motor on the carb, how do u wire this up and what wires dont i need. the wire was cut just after the ali box.
posted on 7/3/04 at 12:15 AM Reply With Quote
is it a pinto? what year, and do you have a haynes book? let me know if you want me to have a look in mine for you.
rich201283
posted on 7/3/04 at 12:56 PM Reply With Quote
ecu
its a g reg granada and its the pinto 2ltr sohc engine
posted on 7/3/04 at 10:27 PM Reply With Quote
as far as i can tell, its got an ESC2 module, a stepper motor and a hall effect trigger on the distributor. This is from the sierra diagrams:
hall effect trigger:
0 bk/r goes to position 7 on the module
+ bn/y goes to pos 20
- bn to pos 15.
carb stepper has 7 wires.
by number as on diagram:
1 bn/gn to 24 on the module
2 w/y to 18
3 w/gn to 5
4 w/b to 17
5 w/bk to 4 on the module
6 w/r to 16
7 w/v to 3
this is all copied from the diagram, not sure if its right cos i didnt stop to understand it, just copied it. However, there are many other wires from the module. there is an idle adjust to earth, two wires to the temp sender, two earths, two that seem to go nowhere but are called octane adjust, a GREEN one to the COIL, various wires to two engine management relays and a few more messy ones.
Bearing this in mind, unless you are one clever git its gonna be very hard to wire it up. So, id recommend either buying the haynes book or looking in a scrapyard to get an engine loom from a similar car.
Good luck anyway...
rich201283
posted on 8/3/04 at 07:12 AM Reply With Quote
its got about 25 pins on the ecu tho
posted on 8/3/04 at 12:25 PM Reply With Quote
yup, 24. as i said, good luck. Id get a haynes manwell myself...
