dan__wright
| posted on 10/6/09 at 01:06 PM |
check my corner weighting please
please can someone check my numbers i weighed the car at the weekend but haven't adjusted it yet (as i dont think it needs doing?)
with me in it
front:
138 : 131
Rear:
148 : 142
do these look okay? 1 KG difference on the diagonals
wilkingj
| posted on 10/6/09 at 01:43 PM |
Not sure I understand your maths there.
Can you show which is Front Left / Right and rear left / right.
I cant see how you can make 1Kg difference with those numbers. Any pair are more than 1Kg apart. Let alone daigonally or in ay direction at all!
Sorry, I cant see what you mean.
AssuMing you have the left front as 138 and right as 131, then the diagonals would be:
138 to 142 is 4Kg difference
131 to 148 is 17Kg difference
Also what about setting the ride height as well.
Best Regards
Geoff
http://www.v8viento.co.uk
greggors84
| posted on 10/6/09 at 01:47 PM |
What he means is;
138 + 142 = 280
131 + 148 = 279
So a 1kg difference between the 2 diagonals.
I would say a 7kg difference across the front isnt too bad for road driving and even some track driving.
If you are happy with your cambers, toes and ride heights I would leave it at that.
Chris
The Magnificent 7!
dan__wright
| posted on 10/6/09 at 02:15 PM |
quote: Originally posted by greggors84
What he means is;
138 + 142 = 280
131 + 148 = 279
7k difference? im lost (do you mean 11?)
i should be able to shift battery etc about to move the weight to the right places hopefully.
checked camber which is perfect (set by eye as well so chuffed!) and ride height is about right for now i think.
[Edited on 10/6/09 by dan__wright]
| posted on 10/6/09 at 02:52 PM |
Looks fine as it is
adithorp
| posted on 10/6/09 at 03:23 PM |
Agreed, look's pretty good .
adrian
http://jpsc.org.uk/forum/
v8kid
| posted on 10/6/09 at 03:29 PM |
Looks good to me too. If you can shift some weight on to the offside well and good ( it might help a little in s bends where the first corner is to
the right) but its fairley academic.
I'm assuming the ride heights are consistent side to side?
oldtimer
| posted on 10/6/09 at 05:50 PM |
I'm suprised there is no more weight on the right side of the vehicle or do you weigh a lot less than your motor??
dan__wright
| posted on 11/6/09 at 11:19 AM |
i was quite surprised by that, think i need to start a new diet and put on a good few KG to balance it out lol.
engine isnt too heavy but then exhaust, cat, battery are all that side and engine is offset and right against the chassis rail.
