Mark Allanson
| posted on 13/6/09 at 04:13 PM |
I just KNEW this was going to be trouble
I started doing my capri axle wheel bearing today.
I removed the wheel, the drum, the 4 set screws which hold the retaining plate, attached the slide hammer...
.. and then spent 4 hours trying to pull the half shaft.
I ache all over, I can hardly move my right arm, my wrist is throbbing, and seriously need a fag (cigarette before anyone gets flippant ) and I
haven't smoked in 15 years.
Please, someone must have am idea how to pull this bearing out
theconrodkid
| posted on 13/6/09 at 04:18 PM |
smack it in,smack it out,drink tea,swear,have a ciggy and smack it again unfortunately,sounds like the outer cage is rusted in or cracked...been there
and still got the scars to prove it
who cares who wins
pass the pork pies
DavidM
| posted on 13/6/09 at 04:20 PM |
If it is anything like the English axle, then remove the bolts from the bearing retainer plate and screw them back in from the other side against the
back of the bearing retainer plates. Use increasing thickness packers until it is out.
You'll need to remove the brake shoes.
Thinking about it, how did you get the bearing retainer plate bolts out without removing the brake shoes?
[Edited on 13/6/09 by DavidM]
Proportion is Everything
big_wasa
| posted on 13/6/09 at 04:27 PM |
I tried every thing, Then I got a slide hammer thats a bit bigger than yours and they came out dead easy.
Try to add weight to the slide.
Mark Allanson
| posted on 13/6/09 at 04:30 PM |
On the capri, the bearing retainer holes are M8 blind, and I don't think there are any packers although I wont know until I get the blessed
bearing out
omega 24 v6
| posted on 13/6/09 at 04:32 PM |
Interesting one as I've just found an oil leak on my axle ( capri) opposite side from you. Where did you source you're bearing or can you
tell me the code number??.
It should/usually comes out no problem but even with a slide hammer or you can't get it to budge?? You could try the heat round the axle tube
trick ( If the bearings already fubared then it won't matter)
Mark Allanson
| posted on 13/6/09 at 04:35 PM |
I did think about heat, but I didn't want to ruin the paint finish, but I am now prepared to used dynamite!
| posted on 13/6/09 at 04:36 PM |
I wonder if someone's used an inappropriate sealer around the bearing...
| posted on 13/6/09 at 04:50 PM |
The slide hammer looks a bit "puny" to me . Mine has a much bigger weight. If all else fails it might be worth putting a bit of heat on
the axle casing or soaking in penetrating oil overnight even if you have to remover the brake shoes and cylinder? One little tip , try WD 40 on the
shaft of the slide hammer .
chris_smith
| posted on 13/6/09 at 06:21 PM |
i had just the same problem , spent one full afternoon with the slide hammer for it to only move 5 mm ended up doing what DavidM^^^ above mentions
turning each bolt quarter of a turn one after the othereventually a huge bang and it popped out, needless to say the opposite side took 10 minutes
chris
Canada EH!
| posted on 13/6/09 at 08:22 PM |
Had the same problem with my Toyota Corolla GTS axle. If you have access to an oxy accetylene torch, heat the area of the bearing on the outside of
the axle housing till it is very warm, NOT RED, then start bulling on your slide hammer. It will come out.
blakep82
| posted on 13/6/09 at 08:47 PM |
yeah, no tricks to it, just have to keep going at it. i was starting to think there was some kind of circlip in the diff, but no.
________________________
Dangle_kt
| posted on 13/6/09 at 08:52 PM |
not linked, but nice garage. I;d love a proper workspace like that.
Mark Allanson
| posted on 14/6/09 at 04:15 PM |
Got the little b'stard!!
Propane torches for 30 mins and it almost fell out (well 10 mins of pumelling!) After that it was only an hour and she was back on her wheels, I
wouldn't like to do the job without a proper press though.
The new bearings are Quinton Hazell QWB151C, and the old ones REALLY did need doing, graunchy and binding. I am really surprised I couldn't hear
them while driving, but that is the benefit of MOT's for you.
Look at the condition of the outer race though
omega 24 v6
| posted on 14/6/09 at 06:46 PM |
Looks like it was well rusted in. Did you get a new retaining collar in the kit??
Mark Allanson
| posted on 14/6/09 at 08:19 PM |
The little ring collar on the inboard side - yes, you need to drill the old one off and press the new one on. I drilled it with an 1/8 drill and it
just pinged and cracked, just slid off after that. The main bearing I had to grind off.
| posted on 15/6/09 at 03:22 PM |
Experience taught me long ago slide hammers aren't that good for this job even the very heavy Churchill jobs that were specified as official
Rootes dealer special tools.
