albertz
| posted on 8/3/04 at 07:00 PM |
Cortina Brake Callipers - Help
Can anyone give me some advice on how to get the calliper pistons out?............i can get then spinning, but they wont come out!!
I have tried using compressed air, without success.
Also, what thread type and size is the bleed nipple and brake pipe connection? I am hoping to run a tap through them to clean them.
Any help appreciated.
Cousin Cleotis
| posted on 8/3/04 at 09:33 PM |
spray with WD-40, push the pistons in as far as they will go, i use a g-clamp, then lever them out 5-10mm using 2 flat head screw drivers or similar.
repeat a few times until they are freed up enough to lever out all the way.
ive never had any luck with compressed air either.
EDIT : http://www.brakesint.co.uk/enterflash.html - if you need seals they are about £5 a caliper from here.
[Edited on 8/3/04 by Cousin Cleotis]
albertz
| posted on 8/3/04 at 09:46 PM |
Cheers, will give it a try.
Blairm
| posted on 8/3/04 at 11:22 PM |
WD-40 is definitly the trick. Took a few minutes soak and out they came. Had already spent about 1 hour witht he air
Hornet
| posted on 9/3/04 at 10:46 AM |
Bleed nipple and brake pipe conn are 10mm x1mm...
cheers
albertz
| posted on 9/3/04 at 11:22 AM |
Sorted
I tried the suggestions posted above, but they refused to budge.
I eventually got them out by taking the servo/master cylinder that i stripped off the donor and coupling it up directly to the callipers, then hand
operated the push rod until the pistons popped out.
A bit time consuming and fiddly, but at least they are out now and cleaned up. Just needing new seals etc - where is cheapest for the seal kits????
Thanks for the thread details, i had to bore out one of the bleed nipples and then clean the thread with a tap.
The joys of brakes...........
[Edited on 9/3/04 by albertz]
ray.h.
| posted on 9/3/04 at 11:38 AM |
Try your local spares shop for all cortina parts.They are now old stock at the suppliers and are rediculously cheap.
that includes all brake parts,cables,electrics,and just about anything else you can think of.
Mix
| posted on 9/3/04 at 11:45 AM |
Seal kits
Try Brakes International www.brakesint.co.uk
or
LSUK, used to be Lucas. Lucas part no SP2589. I paid £10 + VAT IIRC
Mick
madforfishing
| posted on 9/3/04 at 02:31 PM |
I have just had to refurb the seals in my Sierra Callipers. Went to local motor factors place...
The guy there was sound and after some quick maths it turned out as cheap to but new callipers, £10+vat back on the old ones too!!!!
hmmmm, nice.
ceebmoj
| posted on 9/3/04 at 04:17 PM |
Does the place that had the cheap Seara calliper also do cheap Cortena callipers. Falling that can you fit sera or other callipers to the Cortina
upright.
What are the best prices that people have seen on Cotena callipers
Blake
DavidM
| posted on 9/3/04 at 07:12 PM |
Cortina Calipers, £32 each from my local Motor Factor. I think that is an average price. M16's are very common as they are still used in
industrial applications. They seem to be much more expensive from "specialists".
DavidM
| posted on 9/3/04 at 07:16 PM |
By the way, if you screw a bleed nipple into the brake pipe hole and attach a foot pump to this, you can usually pump the pistons out.
DavidM
| posted on 9/3/04 at 07:25 PM |
Oh, and new ones look nice too.
ceebmoj
| posted on 11/3/04 at 08:36 AM |
Does any one know what a good price for a hub is?
| posted on 12/3/04 at 09:59 PM |
Safety note NEVER use compressed air to get the pistons out -- VERY VERY dangerous.
Press the pistons out using hydraulic pressure.
Mark Allanson
| posted on 12/3/04 at 10:47 PM |
You could have somebodies eye out!
| posted on 13/3/04 at 01:09 PM |
A bit more than that an eye out -- a lot of stored energy in a compressed gas, the speed impact of the piston at very close range would be comparable
with a rubber bullet but it ain't made of rubber..
With hydraulic pressure there is almost no stored energy this piston might travel a couple of mm at most.
