Slater
| posted on 3/7/09 at 12:17 PM |
drive shaft joint making noise
Hello
My O/S drive shaft is making a tinny sort of grinding noise. I took the wheel and brake drum off last night, when I turn the drive flange it's
feels very rough and fairly noisy. I am guessing either the wheel bearing or the drive shaft outer joint is starting to break up, probably the
latter.
Where can I get a replacement pair of drive shafts?
They are the push in type, I have drum brakes on the rear.
ashg
| posted on 3/7/09 at 12:55 PM |
someone posted a guide how to referbish the driveshaft joints ages ago. i cant find it on the search but im sure someone post it up
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
GrumpyOne
| posted on 3/7/09 at 01:22 PM |
failing a refurbish you could try
http://www.autopartswarehouse.co.uk/index.aspx
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
