t.j.
| posted on 7/7/09 at 08:13 PM |
prop-shaft Q
I want to prepair my prop-shaft but not sure about the Hardy-disc at the back of the MT-75.
Here is the plan: first the hardy-disc, then the first UJ, then a slip yoke, then at the rear a UJ to connect it to the diff.
Anybody better idea?
[Edited on 7/7/09 by t.j.]
big_wasa
| posted on 7/7/09 at 08:37 PM |
like ths ?
Mine is from dunning and fairbank.
You can turn a spacer that bolts to the tripod then takes a standard uj.
[Edited on 7/7/09 by big_wasa]
t.j.
| posted on 7/7/09 at 08:41 PM |
quote: Originally posted by big_wasa
like ths ?
You can just buy the bits.
Where to buy in NL
The welding and balance will be done around here.
How did you get rid off that disc?
