Author: Subject: brake pins
thunderace
posted on 9/7/09 at 10:56 AM Reply With Quote
brake pins
can i get stainless rod and use it for brake pins or are brake pins high tensile im pretty sure there not but i think its best to check,better safe than sorry
Mr Whippy
posted on 9/7/09 at 11:02 AM Reply With Quote
I use to use old nails in the past! I don't recommend that though
The pins don't take any braking force, they are only there to stop the pads falling out when the piston is not under pressure. If you maintain the brakes properly though, the pins rusting shouldn't be a problem.
