steve m
| posted on 11/7/09 at 09:23 PM |
any idea were i can get wheel spacers like these ?
I am after some wheel spacers that from my rough calculation would be 60mm depth,
They would be normal ford 108 PCd to 108 PCd, and would look similar to these on ebay
http://cgi.ebay.co.uk/Hubcentric-Wheel-Spacer-Kit-Ford-Wheels-on-to-Peugeot_W0QQitemZ220379882898QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?
hash=item334faa2592&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1689%7C293%3A3%7C294%3A50
First question would be how safe are they, and secondly am i looking at having them made specially ?
regards
steve
SeaBass
| posted on 11/7/09 at 09:27 PM |
60mm spacers? Yikes... You'd need to get them made but I wouldn't use them.
[Edited on 11/7/09 by SeaBass]
Paul (Notts)
| posted on 11/7/09 at 09:31 PM |
https://www.burtonpower.com/product_main.aspx?dets_product.aspx?PSet=97&sTxt=wheel%20spacer
I got 20mm ones from above . would think hard about going any bigger!
Paul
Miks15
| posted on 11/7/09 at 09:37 PM |
anyone seen chopshop? They seemed to get away with what must have been over 100mm spacers!
Edit to say im not saying its a good idea or anything just that its been done!
[Edited on 11/7/09 by Miks15]
dave1888
| posted on 11/7/09 at 09:45 PM |
Most of the mr2 ferrari kits use 100mm spacers. defo puts a strain on the bearings.
steve m
| posted on 11/7/09 at 09:55 PM |
I have seen some of these crap programmes were they stick ridiculasley large spacers on
But as mentioned, saftey and bearing wear, means i wont be going down this route !
Thanks for the replys
so 5 rs alloys will be on the for sale board very soon, as the offset wont fit my locost
regards
iscmatt
| posted on 11/7/09 at 11:06 PM |
regards
i think you have made the sensible decision.
clairetoo
| posted on 12/7/09 at 07:41 AM |
Now that brings back memories.........
I wonder if you can still buy `Carlos Fandango` super wide wheels
[Edited on 12/7/09 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
eznfrank
| posted on 12/7/09 at 08:51 AM |
If I remember rightly the chopshop ones were closer to 150mm!!!!
COREdevelopments
| posted on 12/7/09 at 08:55 AM |
i have used 50mm hubcentric spacers. got them from an internet site last year. set me back about 130quid i think. i will try and find the site again.
the spacers are top quality ones and fitted perfect.
Rob
UPDATE try this linky
[Edited on 12/7/09 by COREdevelopments]
nasty-bob
| posted on 12/7/09 at 11:15 AM |
In reply to some of the safety remarks:
I've been thinking a bit about spacers lately and came to the conclusion that there is no difference in terms of load that the hub will see,
between fitting a -60mm offset wheel with a 60mm spacer and fitting a 0 offset wheel.
In fact, from how I've looked at it, load on the hub is more greatly affected by wheel diameter or rolling radius than offset- especially if
you are bringing the offset closer to 0 with the spacers.
In summary, I'd say if its cheaper to fit the spacers, fit the spacers.
Rob
clairetoo
| posted on 12/7/09 at 11:23 AM |
When I built my Fury I was sold front wheel drive offset wheels , and had to fit spacers (I knew nothing about offset , and they wouldnt take them
back )
I still have 22mm hubcentric spacers on the back , using the same logic as nasty-bob the loads are no different to having the correct offset.
The front , however , was a different ball game - with the spacers it was twitchy and hard to steer in a straight line on bumpy roads - so I dumped
the spacers and stretched the wishbones by 22mm .
Problem solved
Claire xx
steve m
| posted on 12/7/09 at 02:38 PM |
After reading the later posts, i am back on thinking about these spacers, as my locost for the last 10 years has been on 13/6j wheels with a 25mm
spacer on the back.
all i am trying to do is use 13/5j rs 4 spokes, as they are considrably lighter, yet the actual wheel track and measurment will be no different to
what it is at present.
even with spacers (unless they are made of lead) will still give a good weight saving, and improve the look ??
COREdevelopments
| posted on 12/7/09 at 03:48 PM |
i have been thinking of the same thing as nasty bob as it was a big decision to use the wide wheel spacers. i didnt want to sell my wheels as i would
of had to buy a new set, so spacers worked out a little bit cheaper and easier. BTW i have only used them on the rear not the front.
Rob
SPYDER
| posted on 13/7/09 at 08:40 PM |
Take a look at these babies on an MR2 355 looky-likey. Spacetastic or what!!!
COREdevelopments
| posted on 14/7/09 at 09:58 AM |
wholey moley!! i would say thats a bit excessive!
