westf27
posted on 12/7/09 at 04:49 PM |
Pinto Hydraulic clutch
As suggested earlier I could go hydraulic to achieve a more suitable clutch operation.The main objectives are to achieve a reliable and light pedal
pressure.It has been suggested to use the Rally Design pull slave cylinder,which looks good but not sure how it works.
The threaded rod I assume is the pull part,the rose jointed end could be an option to power the cylinder,as is the threaded inlet ? .Mounting this to
the engine so that it moves with the engine/transmission must be possible ?.Any suggestions ?
555
omega0684
posted on 12/7/09 at 04:53 PM |
i want to have a look into this as my clutch is unbearably heavy at times!
what reservoir would you fit etc?
how would you mount it?
surely you would have to adapt the rose joint end to attach to the clutch release arm somehow.
[Edited on 12/7/09 by omega0684]
westf27
posted on 12/7/09 at 05:51 PM |
after digging around,it appears the rose end is the fixing point and the threaded end is attached to the clutch arm
555
iank
posted on 12/7/09 at 05:55 PM |
There is a diagram here
http://www.wilwood.com/Products/006-MasterCylinders/011-SC/index.asp
[Edited on 12/7/09 by iank]
Anonymous
westf27
posted on 12/7/09 at 06:15 PM |
just found this,a little closer to understanding.
[img]http://locostbuilders.co.uk/viewthread.php?action=attachment&tid=108112&pid=902347[/img]
555
omega0684
posted on 12/7/09 at 07:16 PM |
how would you do the rose joint end?
i take it the opening on the side is for the clutch fluid the top is the bleed.
would you use a master cylinder like this?
Rally Design Link
westf27
posted on 12/7/09 at 08:50 PM |
will ring them tomoz and find out.Looks like a good idea though.
555
Dingz
posted on 12/7/09 at 08:53 PM |
Recently fitted one of those on a GTM with a K series engine, used an old mini master cylinder and it works a treat. Sorry for the messy picture but I
swapped the ends around and used the rose joint as the anchor point.
omega0684
posted on 12/7/09 at 09:25 PM |
dingz, how have you secured the unit? can i see a bolt into the chassis at the banjo end?
and i can also see that the fluid inlet is on the block side which is a pain in the ar$e!
how have you got around this?
Dingz
posted on 12/7/09 at 09:40 PM |
Here is another shot, there are 2 ports at 90° one is the inlet the other the bleed they are interchangeable so you just need to position/rotate it to
suit. I guess you could fit it like that gold one in your picture but you would need some sort of flexible compliance mounting so the alignment is
ok.
posted on 12/7/09 at 09:51 PM |
The rose jointed end in your picture attaches to the piston, so should ideally attach to the clutch arm. If you fixed this end to a bracket and the
other end to the clutch arm, the entire slave cylinder would move when the clutch was operated which you probably don't want.
Dingz
posted on 13/7/09 at 12:36 PM |
Thats why I swapped the ends around, the non rose joint end has a nice half round ball just the job for fitting on the clutch lever. looks almost as
though they have been just been assembled the wrong way around. Threads are 5/16" unf
