Chaz
| posted on 18/7/09 at 12:35 PM |
Need to undo without mangling the thing! how?
So further to my last thread
http://www.locostbuilders.co.uk/viewthread.php?tid=117725
I need to now undo these!
Chaz
| posted on 18/7/09 at 12:36 PM |
and this one
gavin174
| posted on 18/7/09 at 12:45 PM |
i have never done it but does an angler grinder key fit?
liam.mccaffrey
| posted on 18/7/09 at 12:58 PM |
10 minute job to make a tool for that,
piece of 1/8" plate, drill 2 holes correct distance apart, press/hammer/weld in 2 pins/bolts and scollop out in between to clear the shaft.
[Edited on 18/7/09 by liam.mccaffrey]
Build Blog
Build Photo Album
Chaz
| posted on 18/7/09 at 01:07 PM |
Tried it, doesn't fit.
I also went to a Ford Garage and they didn't even have a tool!
norm007
| posted on 18/7/09 at 01:36 PM |
I made a tool for adjusting Mitsubishi Shogun front hubs by welding some pins onto a socket.
Alternatively, my brother made 2 by grinding a socket to form a Castle type tool to remove a Suzuki GSXR engine and swinging arm
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
owelly
| posted on 18/7/09 at 02:36 PM |
I made a set of tools for taking outboard motors to pieces. They have similar fittings. I used pieces of tubes with 'castles' cut into
them.
http://www.ppcmag.co.uk
liam.mccaffrey
| posted on 18/7/09 at 02:39 PM |
something like this either bought (ebay) or made
Build Blog
Build Photo Album
| posted on 18/7/09 at 03:20 PM |
Ideally, you need to make a tool to fit it but alternatively you could use a punch or a screwdriver as a drift, provided you relieve the area where
it's been punched. It shouldn't be screwed in too tight.
Phil
