m8kwr
| posted on 20/7/09 at 05:55 PM |
What sierra drive shaft for Westfield Rear Uprights
I brought some sierra drive shafts/stub shafts/cv joints from ebay, and they are the wrong size/couling etc, and will not fit
What year/model of sierra should i be looking for to fit a westfield rear upright.
I do not want to make the same mistake twice
minitici
| posted on 20/7/09 at 06:26 PM |
Hi, You need Sierra 4x4 rear shafts with the 100mm OD Lobro bolt on CV joints and stub axle.
To fit to the alloy Westfield uprights you need the Westfield drive flange and bearings. (The Sierra drive flange and bearings are different).
I have a pair of the correct shafts, CV's & stub axles if you need them PM me.
Doug.
