Slater
| posted on 23/7/09 at 09:19 PM |
replacement drive shaft pitted
I just took delivery of a drive shaft from Autoparts Warehouse, it's a reconditioned one for push in diff. However the sealing area at the diff
end looks very pitted to me. See the pic. The shaft even came with the label you can see in the pic!
Do you think it will seal or should I call the supplier and complain?
The oil seals in the diff are were fitted by me and have only done 750 miles. If that makes any difference.
[img][/img]
Cousin Cleotis
| posted on 23/7/09 at 09:30 PM |
looks like a cheap poo recon shaft, i think they paint over the sealing surface to try to hide problems, seen loads like this but not pitted.
Fit it and see, should have a waranty, if it leaks, which i think it will, then take it back.
Paul
matt_gsxr
| posted on 23/7/09 at 10:21 PM |
You can choose how far the seal is banged in when you install them in the diff. Therefore you could set this up so that it seals on non-pitted
region.
If you had got these on the cheap then that is what I would recommend. If you can afford the hassle then I'd get it sorted. As you say they
are not right.
Matt
ashg
| posted on 24/7/09 at 12:04 AM |
thats a bin job send it back. i have had joints with less pitting than that which leak oil
you can tell that who ever supposedly reconditioned it didnt know what they were doing as they have painted parts that shouldnt have paint on them.
if you use it the paint will come off cock your oil seal and crud up the diff.
[Edited on 24/7/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
RickRick
| posted on 24/7/09 at 06:06 AM |
looks to me like it's been sent out to someone else, who's returned it for the same reason after marking it up to highlight the problem
| posted on 24/7/09 at 08:30 AM |
I would not be happy with that at all
Tell us who had the nerve to think that was OK and get it back to them for a refund.
Slater
| posted on 24/7/09 at 08:59 AM |
I called them (AutoParts Warehouse), they asked me to e-mail in a pic with a description of the problem, they should then arrange DHL to collect the
shaft and send me another one.
edit to say.......
Another driveshaft will be sent to me on Monday next week. Result. Hope this one is better!
[Edited on 24/7/09 by Slater]
| posted on 27/7/09 at 10:57 AM |
Sounds like they're dealing with it proprtly then wjich is good.
Hope the replacement is up to scratch!
