Author: Subject: Brake caliper dust seal...lube?
robocog
posted on 30/7/09 at 09:08 AM Reply With Quote
Just about to fit a dust seal to a caliper...and wondered if I need to put any lube inside?
I know you can get red grease that is rubber and brake freindly...but I don't have any
so my choices are limited to what I have already
copperslip...not sure if this will swell the rubber?
LM grease...again unsure
Perhaps a drizzle of brake fluid?
or nothing, just put them on dry making sure the piston is dry when I put it on
Done some searching and not found an answer
Tackling this today and will keep an eye on the forum for words of wisdom :-)
Regards
Rob
cd.thomson
posted on 30/7/09 at 09:31 AM Reply With Quote
I dont know myself robocog, but you appear to have -505 posts :O
Craig
miikae
posted on 30/7/09 at 09:45 AM Reply With Quote
PH grease is the stuff i have used for years , still got the tin i bought in the late sixties , its white in colour.
The grease colour White not the tin made by Castrol.
Mike
[Edited on 30-7-2009 by miikae]
If it can be done it i will be done .
Mr Whippy
posted on 30/7/09 at 09:47 AM Reply With Quote
usually no lube is required, just assemble with clean brake fluid
mookaloid
posted on 30/7/09 at 10:15 AM Reply With Quote
I always put a light smear of red brake grease on stuff like that . I don't like using brake fluid because it attracts moisture and promotes corrosion.
Mark
posted on 30/7/09 at 12:05 PM Reply With Quote
Absolutely, you don't want brake fluid anywhere past the seal.
MautoK
posted on 30/7/09 at 12:14 PM Reply With Quote
Clean & dry, I would think.
Any grease will surely attract and hold muck and grit and make matters worse.
John.
robocog
posted on 30/7/09 at 12:38 PM Reply With Quote
Cheers chaps
Have gone with the "dry method"
All gone well, but of course its pi$$ing down now its done :-(
(sorry its my fault)
As long as it keeps the moisture and cack out I guess it should be OK for another 30 odd years
Regards
Rob
MautoK
posted on 30/7/09 at 03:15 PM Reply With Quote
Racing ahead to -504 now!
Soon be at the top of the list.
robocog
posted on 30/7/09 at 03:57 PM Reply With Quote
only another 503 posts and I'll be back to zero again!
posted on 30/7/09 at 06:46 PM Reply With Quote
Red Rubber grease is the only grease or lubricant apart from brake fluid that can safely be used anywhere near hydraulic rubbers and surfaces.
White brake grease is only for the mechanical parts of a brake system only ---- ie self-adjusters and pivots.
Even a tiny pinprick of WD40 will destroy brake rubbers over time.
