cleowuss
| posted on 6/8/09 at 07:24 PM |
New stub shafts wanted
Hi all
Just had a problem with a rear stub shaft (the shaft in the rear up right) upon tightening it stripped the thread and left the nut thread bound so
after half an hour with the grinder to remove the nut I need a new shaft
Westfield sell the but does any body else?
looked at Burtons they don't seem to sell them any other ideas
durr forgot to say lobro type not push in
Richard
[Edited on 6/8/09 by cleowuss]
On top of the wolds ma!
East Yorkshire Area organiser for Westfield Sports Car Club
minitici
| posted on 6/8/09 at 08:15 PM |
Are you using Westfield Alloy rear uprights?
If so - the Westfield stub axles (Lobro type) are approximately 10mm shorter than the standard Sierra stub axles (from the bolt on flange face to the
inside bearing.
The Westfield upright requires the special Westfield drive flange as their upright has different bearings compared with the Sierra version.
The parts are otherwise interchangeable.
cleowuss
| posted on 6/8/09 at 10:02 PM |
Hi
Yes its the westfield upright and their hub
tightend up the hub nut and it started to spin would'nt tighten would'nt slacken, nut removed via the grinder treads on stub shaft awol,
new stub shaft required need a supplier other than Westfield if poss.
Richard
minitici
| posted on 7/8/09 at 01:07 PM |
I seem to recall that the Westfield stub axles were not too expensive £60 ish.. each (and they are very good quality).
I have one set of second hand Sierra stub axles here.
Doug.
cleowuss
| posted on 8/8/09 at 05:20 AM |
Hi Doug
looks like I have to buy from the factory just hope they have them in stock.
Richard
