Slater
| posted on 6/8/09 at 09:52 PM |
Rear Wheel Bearing Kit
Hi, I have ordered a n/s rear wheel bearing kit for sierra. This arrived, see 1st pic, one bearing and one oil seal.
But looking in the Haynes manual it looks like there should be two bearings (inner and outer) and two oil seals.
Is my kit missing a bearing and oil seal or am I going daft?
  Rear Wheel Bearing
  Haynes RWB
P ?
| posted on 6/8/09 at 10:04 PM |
your missing same again yes
miikae
| posted on 6/8/09 at 10:14 PM |
That looks like a 2RS ball bearing and a seal , which is wrong it should be a kit like
This with 2 seals and 2 taper roller
bearings.
Mike
[Edited on 6-8-2009 by miikae]
If it can be done it i will be done .
Blackcab
| posted on 6/8/09 at 11:01 PM |
I have changed mine today so this is the kit
it also came with 2 outer tapered spigots
Really pleased with the result for a couple of hours and £25
These were how they looked when I took them off
mad-butcher
| posted on 7/8/09 at 07:33 AM |
Just a quick point most kits come with left and right handed nuts,so the one kits fits either side.
Out of curiosity what was the price of the kit
tony
[Edited on 7/8/09 by mad-butcher]
Blackcab
| posted on 7/8/09 at 08:19 AM |
I paid £12.50 per side for mine
Blackcab
JekRankin
| posted on 7/8/09 at 08:20 AM |
I'm interested in the price too - was £25 for both sides or just one?
JekRankin
| posted on 7/8/09 at 08:30 AM |
Where did you get them, Blackcab?
Slater
| posted on 7/8/09 at 08:34 AM |
Blackcab, where did you get the kit from?
| posted on 7/8/09 at 11:04 AM |
Slater,
That looks more like a front wheel bearing kit to me (not necissarily a Sierra one though).
Worth checking p/n with your supplier.
Blackcab
| posted on 7/8/09 at 12:13 PM |
u2u sent
the part code is CD 527
its boxed as continental direct, if you need some getting let me know - but you should be able to get them near you I would have thought
Paul
GrumpyOne
| posted on 7/8/09 at 12:27 PM |
quote: Originally posted by Blackcab
u2u sent
Paul
QH are quoting QWB527 as the same kit so it should be easy enough to get. I am after a WB kit for my rear Scorpio hubs, £46 + drat per side is the
cheapest so far. I think I'll change the hubs to Sierra ones
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
Slater
| posted on 7/8/09 at 02:09 PM |
I have ordered the correct set from my local factors at £18. Thanks for your help.
Autoparts Warehouse will be collecting the one above along with a crappy driveshaft they supplied, I'll be getting a full refund from them. They
have given me 2 wrong/faulty parts and diabolical service.
GrumpyOne
| posted on 7/8/09 at 02:30 PM |
If you don't mind me asking where are you getting them from?
I done a little digging after my last post and the difference in the parts is ABS or non ABS. ABS bearings being 21mm and non ABS 18.5mm.
I am guessing I can use the 18.5mm bearings in my Scorpio hubs (same as Sierra hubs) as it is now non ABS.
Colin
