clairetoo
| posted on 12/8/09 at 07:21 PM |
Master cylinder sizes
I know this is a bit of a numpty question , and some one will be along in a minute to tell me to search - done that , cant find the answer
I am just working on the pedal box of a Fury with twin cylinders/bias bar , it has Wilwoods on the front and stock 9" drums on the back , and
last time I drove it felt very `wooden` .
Both m/cylinders are .700 , and I have been supplied a .625 - but which should I fit it to - front or back ? (bearing in mind willwood billet
dynalites on the front on 285 discs , 35mm pistons I think)
I have allso found the rear m/cylinder is seized solid - which may have accounted for the nasty feel to the brakes ?
[Edited on 12/8/09 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
theconrodkid
| posted on 12/8/09 at 07:26 PM |
smaller dia will give more pressure but longer pedal travel
who cares who wins
pass the pork pies
clairetoo
| posted on 12/8/09 at 07:37 PM |
Thats what I was thinking - the travel felt about right , but then the rear cylinder was solid , so the bias bar was just pivoting on that !
Allso both clevis`s had been screwed in , allmost touching the pedal - that dont look right to me ?
Claire xx
theconrodkid
| posted on 12/8/09 at 07:57 PM |
you cant do a lot with the rear master seized? so replace that first and see how you go/stop delete as appropriate
who cares who wins
pass the pork pies
adithorp
| posted on 12/8/09 at 08:07 PM |
You need the smaller cylinder on the front brakes. Adjust the push rod in the clevis as listed in the tech bulletin on RallyDesign site. Make sure you
have slight free play in the push rods otherwise the brakes will stick on.
http://www.rallydesign.co.uk/balancebar.php
adrian
http://jpsc.org.uk/forum/
| posted on 12/8/09 at 08:42 PM |
That sounds correct, they should be almost but not quite touching the tube that the spherical bearing slides within. This prevents the bar sliding
left and right and randomly changing the bias and also limits the articulation of the bias bar. This means in the event of the failure of one circuit
you can still apply pressure to the other, albeit with increased pedal travel.
