clairetoo
| posted on 14/8/09 at 09:34 PM |
Power steering leak....
Has anybody tried this stuff ?
I have just found a leak on one side of the steering rack on my 164 - it was fine when I bought it , I just got round to working on it tonight
(changed the oil after it has been stood for 8 years...) , and noticed something dripping while warming the engine up
Its cuz I is blond , innit
Claire xx
Will weld for food......
DorsetStrider
| posted on 14/8/09 at 10:30 PM |
I've not used it... however I treat all these quick fix miracle cures with a huge dose of sceptisism.
I'm always happy to be proved wrong thou.
Who the f**K tightened this up!
jollygreengiant
| posted on 15/8/09 at 05:20 AM |
Until you have had power steering failure going into a corner/in a corner/coming out of a corner (delete as appropriate) you will think about doing
anything, except, that is, the correct option of replacing the faulty part.
It take approximately 5 seconds (or less) for the power steering pump to empty the reservoir and then your steering wheel might as well be a torque
wrench undoing the tightest nut you have EVER known.
Oh and you get NO warning of this, unless you happen to spot some leaks/drips.
[Edited on 15/8/09 by jollygreengiant]
bilbo
| posted on 15/8/09 at 07:58 AM |
I did use something similar on an old rover a few years ago, which had a small drip from around the P/S pump. Didn't seem to make any difference
at all
It was going to be a pig to fix otherwise (engine out job to get to the pump), so I scrapped the car and used the engine for my locost build
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
| posted on 15/8/09 at 08:01 AM |
I knew of an FX4 in Cambridge that developed a leak in the PAS , was using a litre a day and in typical taxi driver style (he didn't want to
spend any money) he tried some of the Wynns stuff . A year later it still wasn't leaking . Agreed , doing the job properly would be the ideal
but it's worth a try .
Ninehigh
| posted on 15/8/09 at 08:10 AM |
Probably best to treat it as a temporary fix, but having said that I was in a "temporary" job for a year and a half.
Use it and then when it leaks again fix it properly
| posted on 15/8/09 at 09:10 AM |
The STP equivalent works -- but it won't fix torn or worn seals only works if the seal has lost its elasticity and shrunk and even then how
well it works depends to a great exent on the material the seal is made of.
As rubber like elastomers age they loose oils that are mixed into the polymer this results in the material shrinking and becoming hard. The Stop
Leak products replace the oils lost from the elastomer and restore some of the elasticity and swell the rubber.
However just how well the additive works depends to a large extent on the type of material the seal is made from, it tends to work best on 1960s style
oil seals.
Many leaks in power steering and automatic transmissions are caused by using modern synthetic transmission fluids such as Dextron III in older
systems designed for Dextron IID or similar mineral oil based fluids.
clairetoo
| posted on 15/8/09 at 11:39 AM |
Thats my thinking..............if it works well enough to get it through an MOT I will be happy - once its in use it will have to be fixed
properly.......some time
I dont fancy changing the rack - the car appears to have been built around it
Claire xx
Markymark
| posted on 17/8/09 at 12:33 PM |
Used that in a customers XJS V12 at work (his request)
It stopped the leak all right, stopped his steering working as well!!!!
