Krismc
| posted on 15/8/09 at 01:11 PM |
Handbrake cables?
Failed my SVA 4 months back because my Ford sierra handbrake cable ends are only fixed with u clamps, so ive been trying to get a cable that is
suitable to fit to ford callipers and either my sierra handle or a new handle of similar size, i was told rover one would do but cant find one.
The handbrake needs to be fitted in place and be able to be tightend up after my tunnel is in place? any ideas or links??
| posted on 15/8/09 at 01:27 PM |
I used two Sierra OEM cables and joined them together before the crescent adjuster thingy with wire clamps.
Flamez
My cables run through a rear chassis member where adjustment can be made
and also connects to the handbrake lever via a rod and connector bar;
  handbrake
The cable is now more firmly secured with
these
my build mac1motorsports
| posted on 15/8/09 at 01:45 PM |
Landrover cables on mine Kris with the Rover handle. There are tons of Rovers in the scrap yards, the handle can be found on all the 200 and 400 based
cars from 214/414 to 25/45 and all the MG models.
Drums brakes on mine though so connection at that end may be a problem.. that CAN be overcome!
f1ngers
| posted on 16/8/09 at 08:33 PM |
I failed for the same reason but the tester said that looping the ends of the cables around 'thimbles' and back through the clamps was
acceptable for SVA. Just finished doing mine today but it is a tricky job made easier by removing one of the seats. Got the 'thimbles' off
ebay for a couple of £'s
[img]
[/img]
