| posted on 16/8/09 at 07:11 AM |
oooops - has it all gone wrong
been pondering why my engine is about 1 inch further forward thanit used to be.
also the gearstick is further forward as it is fouling against the tunnel top trim - pretty sure it didn't before.
now the gearbox wasn't really moved other than pivoted on the mounts to lower the front of the engine.
I am wondering if when fitting the engine, somehow the whole lot has moved forwards - I don't think the g/box mounts/rubber have given.
Don't think it is a problem apart from the prop going into the gearbox (4 speed).
The end has to be splined so it is a question of how far is it in - too little and there is a problem.
I will lift the car to see but how would I be able to tell if enough spline is engaged?
Should I unbolt the engine mounts and try to push the engine back to see what happens?
Arrgghh.... so close yet .....
[Edited on 16/8/09 by 02GF74]
Ben_Copeland
| posted on 16/8/09 at 07:26 AM |
Try and push the engine back, or at least find out why its moved !!!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
clairetoo
| posted on 16/8/09 at 08:05 AM |
If you've lowered the engine , shouldn't you lower the gearbox as well ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 16/8/09 at 08:54 AM |
front of gearbos has got lower but rear has gone up a bit - it is rotated on the gearbox mounts.
obviously both ends move in an arc so horizontal distance will have changed but I doun't think that accounts for the 25 mm.
I find it hard to believe that the gearbox mounts are so complaint to allow this.
most perplexing....
| posted on 16/8/09 at 10:54 AM |
Are you using the standard Ford gearbox mounting? They are very flexible, but even the stiffer ones used by Westfield etc. will easily allow the
gearbox to be pivoted up and down by the engine, the mounting simply isn't designed to resist that kind of movement, and if it was it would
break very quickly.
The gearbox being pivoted down at the front certainly explains why the gearlever is up against the hole in the transmission tunnel.
blakep82
| posted on 16/8/09 at 03:17 PM |
have you got photos of the engine mounts?
________________________
