Author: Subject: Panhard rod spherical bearing advice
goodguydrew
posted on 17/8/09 at 12:16 PM Reply With Quote
It's time to make my Panhard Rod.
Some questions:
1.what size of rose joint is recommended
2.where can I get a threaded tube insert.
(anyone got a spare bit?)
3.what size of tube is recommended?
Thanks.
luke
posted on 17/8/09 at 01:32 PM Reply With Quote
i ordered all my rose joints about 2 weeks ago off mcgillmotorsport on ebay. he does all the insterts too.
i got a left handed and a right handed 1/2 rose joint and matching inserts. this means i can back off the lock nuts and just turn the rod to adjust.
as for tube im going for 25mm tube with a 2mm wall. the inserts are 21mm.
blakep82
posted on 17/8/09 at 04:04 PM Reply With Quote
i consider 1/2" (or metric equivalent) thread on the rose joint/insert to be the minimum diameter, but i used 5/8" on all my suspension. fit inside 25mm tube with threaded insert welded in very nicely
________________________
big_wasa
posted on 17/8/09 at 04:55 PM Reply With Quote
I used m12 as that was the fixing Luego put on the axle. I would have used 1/2" as they are cheeper for the same quality. look on ebay you can get the bearings and the weld in inserts from the same place.
goodguydrew
posted on 17/8/09 at 09:35 PM Reply With Quote
Thanks guys.
