Author: Subject: Fitted the New brakes! + pics
nib1980
posted on 23/8/09 at 04:23 PM Reply With Quote
Been busy this afternoon, fitting the new brakes
can't wait to test them, but need to find an adapter fitting between my pipes and the clliper
see below for the change
Anyone fancy a set of M16 callipers and discs?
blakep82
posted on 23/8/09 at 04:27 PM Reply With Quote
very nice
though, not wanting to pee on your strawberries, are those discs on the correct side?
________________________
philw
posted on 23/8/09 at 04:29 PM Reply With Quote
I was just thinking that, it depends on the shape of the vanes though.
Just go out for a drive(not dangerous) if they make a strange noise then you will know
[Edited on [1251045081R0=043131p: by philw]
Must try harder
nib1980
posted on 23/8/09 at 04:40 PM Reply With Quote
nope there definatley wrong. well spotted you passed the test, now who ever puts the labels in really small letters, i'm going to tear there bits off. BYE................
Can hubs be swapped from side to side? as getting the discs on was apain.
[Edited on 23/8/09 by nib1980]
blakep82
posted on 23/8/09 at 04:46 PM Reply With Quote
i don't see why the hubs can't be swapped over...
Mark G
posted on 23/8/09 at 05:09 PM Reply With Quote
Originally posted by blakep82
very nice
lol, my thoughts as soon as I saw the picture.
prelude1980
posted on 23/8/09 at 05:17 PM Reply With Quote
can't you have the grooves on the discs pointing both ways, 1 way for increased braking, wear on the pad and noise. The second way decreases the wear on the pad and lowers noise
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
Stuart_B
posted on 23/8/09 at 05:21 PM Reply With Quote
i hope it is not wrong as it is the same way i fitted teh brakes, and they are marked left and right on the box, and i put teh left one on teh left and teh right one on the right. unless i was looking from the wrong end.
i looked from the back off the car.
stuart
nib1980
posted on 23/8/09 at 05:22 PM Reply With Quote
stuart
hmmm interesting, maybe i'm not wrong?
anyone else got any opinions?
flak monkey
posted on 23/8/09 at 05:29 PM Reply With Quote
V nice did mie last year, was well worth it.
As for the grooves, depends who you listen to. But FWIW in my book they are on the wrong side.
And yes you can just swap the hubs over
Sera
http://www.motosera.com
thefreak
posted on 23/8/09 at 05:36 PM Reply With Quote
The grooves dont relate to which way the disks go on. they can be slotted either way depending on the manufacturer.
The way to check without doubt is to check which way the vanes go inside the disk (if it has them). If they are solid disks, they can be either way. the way these are fitted will be more aggressive on the pad.
posted on 23/8/09 at 09:55 PM Reply With Quote
Leave them as they are, it won't make any difference with solid disks.
