catman
| posted on 26/8/09 at 12:41 PM |
lsd
anyone using an lsd from a tin top in there 7type, im thinking of getting one untill i can afford a tran-X. but im concerned that they are designed
for a heavy car, therefore will be either inaffective or snatchy. should i buy it as its half the price of a new one with the correct ramp angles? i
could sell the second hand one in a year when i can upgrade, it should hold its value
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
Charlie_Zetec
| posted on 26/8/09 at 02:00 PM |
Just as a side note, I wouldn't use a Tran-X lsd, it's very harsh indeed. I had one in a VX C20LET turbo engined Mk 2 Astra and it was
very "snappy" in terms of being on or off. I even took it out and changed the lock ratio (had 2 different options), but still no luck.
My later Calibra C20XE with a 6-speed gearbox had a Quaife lsd, and it was a much nicer unit.
Still, that was just my opinion, and I'm sure everyone will have their own thoughts on the situation.
2p added!
eddbaz
| posted on 26/8/09 at 03:09 PM |
Loads of cars use sierra lsd's with no problems, starting to get more expensive now as they are becoming more scarce but you can pick up a good
working unit for around £150 or less as long as its the more common ration of 3.62/1
blakep82
| posted on 26/8/09 at 03:52 PM |
i wou;d go for a quaife atb over the tran-x. its a bit more gentle i understand. cheaper too i think
________________________
catman
| posted on 26/8/09 at 03:53 PM |
ive got a 3.75cwp in my standard diff so im only after an atlas LSD.
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
