speedyxjs
| posted on 26/8/09 at 06:44 PM |
Brake servo
My donors brake m/c has a built in servo.
If i decide not to use the servo, can i just leave it as is or do i need to plug the holes?
r1_pete
| posted on 26/8/09 at 06:59 PM |
You need to remove the master cylinder from the servo, some you can mount seperately, and have the push rod operate directly on mc piston.
As with a servo car without the engine running, the brakes wont work effectively if you leave it in.
speedyxjs
| posted on 26/8/09 at 07:33 PM |
Thanks Pete, it doesnt look like its going to be very easy to take it out so i may have to try and work out how to get get the servo plumbed in.
speedyxjs
| posted on 26/8/09 at 08:00 PM |
Iv just found ou that the servo is powered by a hydraulic or electric (model dependant) pump, neither of which i have on my new engine
Does anyone have any suggestions?
mark chandler
| posted on 26/8/09 at 09:04 PM |
Brakes on the axles are still the same, push fluid in pistons come out.
Just stick on a regular master cylinder ( I expect what you have will be okay though without the extra gubbins) from a car, I used a new landrover one
as it was cheap, works fine with discs front and back.
You XJ40 brakes will have a similar surface area to my 4 pot brakes up front and sierra rears.
Regards Mark
theconrodkid
| posted on 27/8/09 at 06:41 AM |
didnt some jags use mineral fluid?if so using regular fluid it would sh*g the caliper seals
who cares who wins
pass the pork pies
