LBMEFM
| posted on 7/9/09 at 08:20 PM |
Road springs
Silly question this but just to clear any doubt in my mind, I have fitted the 300lb rating springs to the rear and the lighter 200lb springs to the
front on my MK Indy-Blade that is right isn't it.
Mark Allanson
| posted on 7/9/09 at 08:21 PM |
I doubt it!
| posted on 7/9/09 at 08:23 PM |
I foresee some spring swapping in your near future
ReMan
| posted on 7/9/09 at 09:20 PM |
I have the std 300?lb on the back and bought 225 for the front.
So leave them where they are fpor the time being I say
Frosty
| posted on 7/9/09 at 10:47 PM |
Yes, if you like going sideways
300lb springs are very heavy for the rear of that car, even with 2 passengers on board. You must remember that the damper connects directly to the top
of the rear upright, so no suspension leverage to factor in.
I expect that 200lb would be much better suited to the rear of the car. The front rate depends on which kit you have, but on the standard Indy I think
225lb gives a nice balance for a BEC.
This was based on calculations only, but I'm certain they will work well.
Kartdad
| posted on 8/9/09 at 07:36 AM |
If I remember correctly the 300lb go on the front and the 200lb go on the back, this
is how the racing set up is described.
ReMan
| posted on 9/9/09 at 09:03 PM |
300lb font is is too heavy for a BEC
Ray Evans
| posted on 24/9/09 at 11:25 PM |
Spring rates
On mine the shocks move 50mm for 84mm of ride height change to the harder springs are need on the front due to this leverage.
Ray
