SeanStone
posted on 14/9/09 at 10:29 PM |
Calipers for 13" rims
Hi there, I have a set of these http://harrier-register.co.uk/images/7.5%20rs%20wheel.jpg
and I am looking for a set of calipers to fit under them. I have been advised that the midilite caliper by wilwood will fit but it is pretty pricey.
Some forums seem to think the superlite caliper will fit, which is much more affordable.
I am using sierra uprights which currently have cosworth 4 pots on. Way too big
nib1980
posted on 15/9/09 at 06:35 AM |
willwoods will fit, i just bought some.
whjat uprights do you have? sierra or cortina?
if cortima I have a set of M16 callipers. not wilwood, but fairly potent twin pot. i'm sure some one will be able to advise in more depth
SeanStone
posted on 15/9/09 at 07:55 AM |
What calipers did you buy and what rims did they go on?
I'm using sierra uprights
bigrich
posted on 15/9/09 at 08:12 AM |
I haves powerlites front and rear on mine, used 2 different makes of 13's (compomotive and team dynamics) Fronts have loads of clearence, the
rears with the handbrake set up is tight for space
SeanStone
posted on 15/9/09 at 08:16 AM |
Thanks. Do you know the inner diameter of your wheels?
