Author: Subject: ball joint q.
tcr
posted on 20/9/09 at 06:14 PM Reply With Quote
ball joint q.
how do you remove a ball joint carefully ? they passed mot but need to be removed to have bones coated and at £56 each (dolomite suspension) i want to re use them any suggestions welcome
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
prawnabie
posted on 20/9/09 at 06:17 PM Reply With Quote
Id use a scissor type ball joint splitter if you are keeping the joints, anything else gets the fork!
posted on 20/9/09 at 06:18 PM Reply With Quote
Even with the scissors if you're ham-fisted you can shag the rubber boot thingy.
I tend to use it as an opportunity to fit new ball joints.
Otherwise scissors are the way forward....
prawnabie
posted on 20/9/09 at 06:20 PM Reply With Quote
You'd have to be pretty unlucky do do that lol
tcr
posted on 20/9/09 at 06:21 PM Reply With Quote
the thing is i know they are ok and they cost £120 a pair
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
maartenromijn
posted on 20/9/09 at 06:26 PM Reply With Quote
Try to use 2 hammers: a 2kg hammer to hold against the body of the BJ (as some kind of counter weight. A 0,6 kg hammer to hit the other side of the BJ body. Sometimes it snaps loose.
PS: don't be too gentle
BLOG: http://thunderroad-super7.blogspot.com/
andkilde
posted on 20/9/09 at 06:27 PM Reply With Quote
For £120, I'd carefully paint the bones by hand and powder coat them once the ball joints were shagged.
t
r1_pete
posted on 20/9/09 at 06:29 PM Reply With Quote
Two hammers, one held against the back of the arm where the joint taper fits, and another to hit the other side, BJ nut removed of course.
tcr
posted on 20/9/09 at 06:32 PM Reply With Quote
t
ha ha good answer
gonna try the 2 hammers ..not tonite though cos its beer o'clock
[Edited on 20/9/09 by tcr]
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
posted on 20/9/09 at 06:39 PM Reply With Quote
Because the joints are so small take it off the upright that the ball joint and bottomm wishbone to the bench and use a small track rod end press splitter rather than the usual press splitter or fork splitter.
Hope you are not putting spring loads through Dolomite bottom ball as they aren't up to the job --- I have seen the balls pop out on Triumphs.
tcr
posted on 20/9/09 at 06:51 PM Reply With Quote
they been ok so far and the car has had some hammer .when u drive a robinhood ball joints are the last thing on your mind
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
robinj66
posted on 20/9/09 at 09:08 PM Reply With Quote
You can replace the rubber boots if they are damaged - try a search on Ebay for "rubber boot"
Canada EH!
posted on 20/9/09 at 11:51 PM Reply With Quote
My vote the two hammers, it does work.
tcr
posted on 26/9/09 at 10:40 PM Reply With Quote
new ball joints now on order
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
