Author: Subject: Sierra Driveshafts Threads.
Coopz
posted on 21/9/09 at 09:12 PM Reply With Quote
Quick question.. I sent my push in driveshafts to car parts direct and got the reconditioned ones sent back to me.
I went to fit them to the car the shorter one (passenger side) the hub nut tightens towards the front of the car, which I think is correct. The longer shaft (drivers side) hub nut tightens to the rear. When i thought it should tighten to the front.
Is this a problem will it be ok should I try get it changed?
MikeFellows
posted on 21/9/09 at 09:14 PM Reply With Quote
I would expect one of the threads to be a left hand thread (so it doesnt loosen as the wheel turns forward)
sounds fine to me
Thinking about it
posted on 21/9/09 at 09:16 PM Reply With Quote
Clockwise thread on offside and anticlockwise on the nearside. It looks like they have put the wrong end on the offside shaft.
MikeFellows
posted on 21/9/09 at 09:47 PM Reply With Quote
I should have RTFA properly before replying
ashg
posted on 21/9/09 at 11:57 PM Reply With Quote
sierra drive shaft nuts should go tighter turning towardsthe front of the car and undo turning towards the rear of the car. simples.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mrwibble
posted on 23/9/09 at 12:18 PM Reply With Quote
mine had a left handed thread on the passenger side. this was not the "lobro" drive shaft which i think was used on the dohc engined cars?
posted on 23/9/09 at 12:52 PM Reply With Quote
That is correct; the nut should tighten in normal direction of rotation of the wheel.
