speedyxjs
| posted on 23/9/09 at 11:56 AM |
How to fit the clevis pin?
I brought a sierra brake master cylinder from marmot0 a few weeks back which came without a clevis pin. I asked what i needed to fit one to the MC and
he suggested one of these with a cut down bolt to connect it.
The problem is, if the brake pedal moves forward and pulls the clevis pin out of the MC, im left with no brakes.
How can i get round this?
I hope MikeFellows doesnt mind me using his picture but it was the only one i could find to show this on.
[Edited on 23-9-09 by speedyxjs]
Macbeast
| posted on 23/9/09 at 12:04 PM |
I'm in the same situation. I think the answer is to fit something to the brake pedal (a back stop? ) to prevent it coming back too far.
[Edited on 23/9/09 by Macbeast]
marmot0
| posted on 23/9/09 at 12:06 PM |
have a look here on page 7
http://www.rawengineering.co.uk/SrtikerMnlSep2005.pdf
Flamez
| posted on 23/9/09 at 12:08 PM |
I just used threaded bar which attached to the clevis on the pedal. Also fitted a pedal stop.
You could use this
my build mac1motorsports
bbwales
in the Chris Gibbs book that is in fact what you do. If the pedal is floor mounted you have a stop bolt on the floor which prevents the push rod from
disengaging from the M/Cyl on top mounted pedals use a spring to hold it in contact.
Hope that helps.
Bob
Mr Whippy
| posted on 23/9/09 at 12:10 PM |
as above, the old beetle has this problem and it just uses a bolted on bended metal bracket to prevent the pedal falling forwards.
[Edited on 23/9/09 by Mr Whippy]
Ben_Copeland
| posted on 23/9/09 at 02:03 PM |
Thats the answer. Pedal stop stops the pedal falling forward, the bolt/clevis pin should tight between the pedal and the master cylinder.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
mad-butcher
| posted on 23/9/09 at 04:22 PM |
not a very good pic but it's how MK do it and seems to work OK, needs a piece a 1/8" ally under the bolt head to stop floor wearing
piccy
tony
MikeFellows
| posted on 23/9/09 at 05:08 PM |
hey are they my fags?
feel free to use all the pics i take
[Edited on 23/9/09 by MikeFellows]
