graememk
| posted on 23/9/09 at 09:54 PM |
steering dog leg
what have people used as a bearing ?
got any pics ?
mark chandler
| posted on 23/9/09 at 10:12 PM |
No picture but a lot of people use the ubiquitous Mcgill rose joint, no need to worry about perfect alignment then.
Regards Mark
| posted on 23/9/09 at 10:34 PM |
Just took the damper off mine, bushes, not bearings..
MikeR
| posted on 23/9/09 at 10:45 PM |
if this is to hold a steering column with two uj's in it, i used a anti roll bar bush.
Its designed to hold something that twists and for me was a fraction larger than the size of the tube so has no friction.
Mr Whippy
| posted on 24/9/09 at 08:36 AM |
I have the same problem with the falcon and was going to use one of these -
linky
the range they do - linky2
[Edited on 24/9/09 by Mr Whippy]
tegwin
| posted on 24/9/09 at 08:38 AM |
On the TVR I machined a nylon top hat and pressed it into a steel tube welded to the chassis...
On the Robinhood I used a bearing like what whippy said!
www.verticalhorizonsmedia.tv
