Author: Subject: sierra 4x4 front hubs?
scoobyhunter
posted on 24/9/09 at 01:21 PM Reply With Quote
hiya,is it possable to use sierra 4x4 hubs on the front? i cant picture them in my head,as i remember i would need the driveshaft ends to keep the hub together is this right? its just that i can get hold of some for a good price.
regards,andy
Mr Whippy
posted on 24/9/09 at 01:47 PM Reply With Quote
yeah you need the driveshaft end to tension the bearing just like the rear, this is what is bolted to the upright.
Ben_Copeland
posted on 24/9/09 at 06:45 PM Reply With Quote
AFAIK you cant use them without drveshafts. Plus i think the insides would get dirt and crud in there, which cant be good !
Ben
Locost Map on Google Maps
Enter Your Details Here
scoobyhunter
posted on 24/9/09 at 10:36 PM Reply With Quote
i think ill go for normal sierra,or would anyone reccomend anything else? bearing in mind im on a tight budget of next to nothing! cheers.
Liam
posted on 25/9/09 at 04:42 PM Reply With Quote
You'd have to gut a CV and use the splined stub to hold it all together as said above. Geometry is different, bottom balljoint is different, and you'd need to have custom bigger mushroom adaptors made for the top joint. You'd have to really want to use 4x4 ones for some unknown reason to bother to sort all those issues!
EDIT: Ah - I've assumed you were talking about the whole front upright/hub assembly.
[Edited on 25/9/09 by Liam]
