robocog
| posted on 24/9/09 at 05:53 PM |
remote brake reservoir suitable hose
Hi fitted a new master cylinder, made up some adapters that push fit into it and have got a remote reservoir (Daihatsu Hi Jet) and have temporarily
fitted some fuel safe hose to join the two together
Is fuel spec hose OK to use for this purpose?
Don't want to trash the master cylinder prematurely! and now paranoid its going to do bad things despite it seeming like a really good idea at
the time
Regards
Rob
[Edited on 24/9/09 by robocog]
Dusty
| posted on 24/9/09 at 06:00 PM |
Brake fluid creeps through all sorts of plastics. I got some hose from here. It's
on as fuel hose but read the specs and they have stuff that is OK for low pressure brake fluid. Standard fuel hose is probably not OK.
[Edited on 24/9/09 by Dusty]
iank
| posted on 24/9/09 at 06:14 PM |
The best way is to use OEM ones from a Fiat Seicento.
See this thread for part numbers.
http://www.locostbuilders.co.uk/viewthread.php?tid=69243
Proper markings the IVA man can't argue with as they are OEM and they are unlikely to start leaking (as much of the stuff sold as reservoir hose
does after a few months. Also dead cheap.
Anonymous
Dingz
| posted on 24/9/09 at 06:52 PM |
Assuming you are using DOT 4 or 5.1 (glycol based) you will need hose made from EPDM rubber, some water hoses are made from this, fuel hose is no good
I'm afraid.
robocog
| posted on 24/9/09 at 07:08 PM |
Cheers for the fast reponses
Just been on eBay and bought a metre of this stuff
Clickety Click
Says its the right stuff, hopefully its going to stretch over 8mm barbs OK
Regards
Rob
