MK9R
| posted on 29/9/09 at 10:51 AM |
Replace upright Lower ball joint with rose joint and conical
Any idea of where i could get a rose joint with conical bolt set up to replace the lower ball joint on my fury, makes adjustment of camber so much
easier.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
TimC
| posted on 29/9/09 at 10:52 AM |
I was going to do the same with my MNR but I reckon you'll need to get it (the cone) turned. Send a U2U to Flak Monkey.
MK9R
| posted on 29/9/09 at 10:55 AM |
Got access to lather and minimal skill to do it myself, but just don't have the time to wipe my arse, let alone making stuff like this The
missus will hit the roof when she sees me angle grind the front end of the chassis and the resulting rebuild work its going to take!
Cheers Austen
RGB car number 9
www.trackace.co.uk
