Hugh_
posted on 4/10/09 at 10:15 PM |
Build leftovers (
As my nightmare rebuild comes to a close at last, albeit at completely the wrong end of the summer (ooops!), here are the bits I've
removed/bought in error that may be of use to someone, FOC if collected unless price stated: Happy to post if my costs are covered, or collection
from near Cranbrook, Kent (I work in Maidstone and I’m near Crawley a fair bit at the moment as well if either is more convenient). Pics of specific
items on request
Parts for sale 1
Parts for sale 2
- MDF dash to suit locost scuttle with Escort 1.3 clocks (with custom glass and bezels), rev counter adapted to 9k rpm, with hazard and fog lt.
switches. Previous leatherette covered, will either need recovering or use as a template (as I did) £10. dials maybe gone to possibly gone to
madrallysport
- Speedo cable to suit above for Ford/type 9 Gone to daddylonglegs
- Smiths 50mm water temperature gauge £5
- Smiths 50m oil pressure gauge (mechanical) £5
- VDO 50mm oil pressure gauge (electrical) £10 gone to madrallysport
- VDO 50mm voltage gauge (8-16v) £10
- Unknown make 50mm fuel gauge £5
- Fuel sender with 6 bolt flange (will need O-ring), possibly matched to above, I’ll check £5 gone to thefreak
- CBS hazard light kit (opened but unused) £8 gone to ashg pending collection
- Gear level and handbrake surrounds gone to Charlie_Zetec
- Side mirrors gone to speedyxjs
- Centre mirror (sierra??) adapted to 3 hole base £5
- CBR 600 indicators gone to GrumpyOne
- Side repeaters (no bulb holders)
- rear reflectors gone to speedyxjs
- reversing light lens and reflector (no casing)
- Large tadpole rim (~1.2m) £2Gone to daddylonglegs
- Brake reservoir cap
- 32mm ID cooling/rad hose (0.6m @ £5, 0.1m and 0.07m lengths FOC)
- 2x 32mm hose joiners
- 38mm in line temp. sender housing £5
- Shocks/springs – 12” & 11”, nackered but ok for during build? gone to Alex. pending collection
- Petrol King fuel saver (fuel regulator) – leaked when fitted inverted (ooops!), untested right way up. £5 gone to madrallysport
- Pinto (?) Ignition module (Motorcraft 83BB 12A199 B3A) gone to ashg pending collection
- 2x unknown coil (one genuine land rover part!)
- Water pump £5
- X-flow starter motor (FRS13) £25
- Pedal box (clutch and brake), roof mounted on chassis rail and secured through bulkhead, with bracket to take servo (uses same bulkhead mount
points) with integral steering column support. £15
- GATE front mount 12” fan £10
- Escort 1.3 rad. with cap; moderate leak.
- Pinto cam cover with cut down filler neck gone to ashg pending collection
- RS2000/Pinto inlet manifold to suit twin carbs (Dellorto 45s fit, unsure what others will), coolant return will need re-tapping £25
[Edited on 4/10/09 by Hugh_]
[Edited on 5/10/09 by Hugh_]
Charlie_Zetec
posted on 4/10/09 at 10:38 PM |
First dibs on the handbrake and gear lever surround, please!
Not in Kent anytime soon, so will require posting - just let me know how much.
GrumpyOne
posted on 4/10/09 at 10:39 PM |
Hi There
Could I have the CBR 600 indicators, posted to Aberdeen, please?
Colin
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
Hugh_
posted on 4/10/09 at 10:58 PM |
All replied to by U2U
speedyxjs
posted on 5/10/09 at 06:06 AM |
Side mirrors and rear reflectors please
[Edited on 5-10-09 by speedyxjs]
madrallysport
posted on 5/10/09 at 07:35 AM |
u2u sent re - oil pressure gauge, petrol king, dash
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
ashg
posted on 5/10/09 at 08:54 AM |
i will have the rocker cover and ignition module.
i work in maidstone so can grab the bits one lunch time
will also have the hazard circuit too.
U2u sent
Ash
[Edited on 5/10/09 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Hugh_
posted on 5/10/09 at 09:51 AM |
All replied to by U2U, fantastic response so far, didnt think most of it would go!
ETA: I'll get everything that's goes today in tomorrow's post if I have addresses in time.
Daddylonglegs
posted on 5/10/09 at 10:18 AM |
I'll take the tadpole trim and speedo cable please
JB
Hugh_
posted on 6/10/09 at 04:27 PM |
Everything going by post that I have an address to send to has gone this afternoon, I'll send U2U's re postage costs later.
Hugh_
posted on 8/10/09 at 10:27 PM |
Inline water temp sender housing, fan and inlet manifold gone to arrow-engineering.
ps. why wont it let me edit my post any more?
