Author: Subject: How to Identify M/C
Daddylonglegs
posted on 6/10/09 at 12:25 PM Reply With Quote
How to Identify M/C
Can anyone tell me how to identify my Sierra M/C please? If I decide to use it then I want to know what servicing kit to buy.
Ta
JB
James
posted on 6/10/09 at 12:30 PM Reply With Quote
Well one way might be to put a pic' up on here.
Or search the pics on the brakesint website and match it that way.
James
Daddylonglegs
posted on 6/10/09 at 12:36 PM Reply With Quote
James
I'll do that tonight sir
Reason I asked 'off the cuff' is that I heard there are 2 types and the distance between the outlets tells you which one?
JB
Mr Whippy
posted on 6/10/09 at 12:44 PM Reply With Quote
type the part number on it into google
Daddylonglegs
posted on 6/10/09 at 12:47 PM Reply With Quote
Is that the number on the casting? (if so, which one )
[Edited on 6/10/09 by Daddylonglegs]
Mr Whippy
posted on 6/10/09 at 12:54 PM Reply With Quote
try them all...
the pistons inside also have part numbers on them and will be easy to identify, this e-bay shop has several kits with the part numbers shown.
You can only judge the condition by opening it up anyway and seeing if there’s is a ridge on the inner bore wall. If there is its junk and best replaced as the lip can flip the seal over and you lose the brakes, that happened to my cortina and I ended up going though a fence and into a field.
bay linky
Daddylonglegs
posted on 6/10/09 at 01:05 PM Reply With Quote
..... as the lip can flip the seal over and you lose the brakes, that happened to my cortina and I ended up going though a fence and into a field.
If you're trying to scare me it's working
Thanks for the input. I'll have a look-see. If it's pooped, I may as well try and get one of them there Fiesta non-servo ones someone reccomended on here.
Bluemoon
posted on 6/10/09 at 02:09 PM Reply With Quote
^^ but surely as the Sierra is a dual circuit system you would only loose one circuit.. You should still have some brakes??? (not ideal!! I replaced my MC with a new one, as you couldn't seem to find a repair kit for my old one)..
Dan
Mr Whippy
posted on 6/10/09 at 02:22 PM Reply With Quote
Dan
hmm trust me even with dual circuit brakes, whats left when a hose or whatever lets go is not anything like half the brakes, opening the doors wide would be as effective
As a test the next time you bleed the brakes, leave air in one of the circuits and try and stop the car, don't go fast mind or on the road & make sure the handbrake works
adithorp
posted on 6/10/09 at 06:17 PM Reply With Quote
There's usualy a number stamped on the end.
http://jpsc.org.uk/forum/
posted on 6/10/09 at 07:20 PM Reply With Quote
There are at least six different types of Sierra brake master cylinders. Three Girling and three Bendix. Girling do the cast iron and steel tube cylinders and Bendix do cast aluminium. If you've got the aluminium cylinder, you're gonna really struggle to find a repair kit.
Phil
Daddylonglegs
posted on 6/10/09 at 07:24 PM Reply With Quote
As it happens I don't need to worry what type it is now....
Managed to get the thing stripped down.....after several attempts and many choice words!...the primary piston finally came out, but there is no way that the secondary was going anywhere (and yes, I did remember the holding pin ). Upon further investigation there is more pitting in the bore than on our local roads!
So I guess it's time to buy a new MC. Only thing now is, which one ???
posted on 6/10/09 at 07:34 PM Reply With Quote
Personally, I'd try a Ford Fiesta Mk1,2 brake master cylinder. Lucas PMC101(74066357) - For vehicles without servo 17.5mm dia.
Phil
Daddylonglegs
posted on 6/10/09 at 07:52 PM Reply With Quote
Cheers for that Phil. Would this be any good?
Oh well.....I guess posting the link prompted someone else to buy it instead then?? Thanks whovere you are....
