speedyxjs
| posted on 9/10/09 at 06:22 AM |
Brake M/C three outlets
My MC has 3 outlets. I know for IVA you need a diagonal split so what do i do with the third outlet?
t16turbotone
| posted on 9/10/09 at 06:32 AM |
is it a sierra item? output 1 nearest the bulkhead goes to rears...output 2 middle goes to front left....output 3 furthest from bulkhead to front
right
you will probaly have to have some kind of restrictor valve fitted in line with rears to prevent overbraking on rears....i did
flak monkey
| posted on 9/10/09 at 06:53 AM |
Yep if its sierra, 2 to end ones (furthest from bulkhead) to front wheels, single outlet to rears.
I didnt need a rear restrictor in mine with drums at the back, though you will if using discs.
Sera
http://www.motosera.com
speedyxjs
| posted on 9/10/09 at 07:02 AM |
Im hoping to use the Jag one (if the exhaust doesnt melt the reservior)
Doesnt the IVA manual say that one pipe needs to act on two diagonal wheels?
speedyxjs
| posted on 9/10/09 at 07:09 AM |
From IVA manual:
The vehicle must be fitted with a split (dual) circuit brake system with each part of the system operating on at least two wheels (one on each side),
capable of operating in the event of a failure of the service brake or its power assistance.
Mr Whippy
| posted on 9/10/09 at 07:13 AM |
no you can have either diagonal or front and back, so long as its not two wheels on just one side as then the car would try and turn
[Edited on 9/10/09 by Mr Whippy]
Daddylonglegs
| posted on 9/10/09 at 07:17 AM |
That reads to me that, as long as you have the front and rear on seperate circuits that will be fine.
I think
speedyxjs
| posted on 9/10/09 at 07:23 AM |
Ok cheers. Reading what i just quoted, i dont know where i got the diagonal from
Mr Whippy
| posted on 9/10/09 at 07:28 AM |
neither do I, go and get some coffee
l0rd
| posted on 9/10/09 at 08:27 AM |
Probably because i mentioned it some time ago that Renaults use this configuration.
splitrivet
| posted on 9/10/09 at 09:18 AM |
Ah t'interweb you could virtually hear hundreds of car builders repiping their brake lines shortly after that post.
Bob
