A Badger
| posted on 2/4/04 at 09:43 PM |
Suspension bolt sizes
I'm working my way through the part finish +4" Pinto powered machine that I bought.
The further I get the more I keep re-dooing. Anyway I've been looking a the rear suspension today whilst installing my shocks. For the Shock
Mountings I've used nice new Stainless 8.8 M10's, however it looks like the trailing arms are mounted using M8's.
Are these strong enough or should I change them all the M10's?
Guess I better check the front too.
Andrew
| posted on 2/4/04 at 10:46 PM |
if they are high tensile im sure they would be ok at m8. surely? doesnt the 8.8 stand for something like 8.8 tons in shear?
stephen_gusterson
| posted on 2/4/04 at 10:58 PM |
8.8 if the case would be at a specific cross sectional load - a 6mm 8.8 and a 10mm 8.8 would be different shear loads.....
my shocks have 10mm bolts as std and are 8.8
atb
steve
Dusty
| posted on 2/4/04 at 11:40 PM |
Nope. Specification of 8.8 (and S in old money) means tensile strength of up to 50-55 tons per sq inch. Doesn't specify shear strength.
type 907
| posted on 3/4/04 at 07:23 AM |
Hi'
Since I'm building a stainless chassis I'm
using s/s bolts.
I Hope I can persuade the man at SVA
that 8.8 = A4 80 (see chart)
sorry it's in new money.
Paul G
Too much is just enough
Dick Axtell
| posted on 3/4/04 at 07:29 AM |
Damper Mounting Bolts
Hi All,
Thought these were 1/2 inch UNF as standard?? Certainly are for the GTS Nitron units. Moreover, the pre-welded chassis attachment brackets were
drilled to 1/2 inch holes.
Trailing arms & wishbones should be mounted using M12 bolts, for adequate road-going suspension security.
[Edited on 3/4/04 by Dick Axtell]
| posted on 3/4/04 at 12:28 PM |
I don't understand the question.
You use the bolts that fit your suspension bushes. The original Triumph ones were nothing like m12 and they held. If you are using polybushes they
might be m12 depending on the crush tubes supplied.
| posted on 3/4/04 at 12:46 PM |
Yes on the front wishbones Triumph used 7/16" unf -- a tiny bit bigger than 11mm
Lotus used 1/2" on the Elan wishbones but they were mounted in single shear
chrisg
| posted on 3/4/04 at 01:09 PM |
Didn't know you could get 8.8 grade stainless bolts, and I though it was decided in the last disscusion we had that stainless weren't
suitable for suspension jobs?
Or did I dream it?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
| posted on 3/4/04 at 03:51 PM |
The teeth on JCB buckets are a type of stainless steel --- stainless steels can be more than strong and tough enough just a question of the type of
stainless steel and the cost.
craig1410
| posted on 3/4/04 at 06:26 PM |
Chris,
Yes I remember something about that too. I did some checking on the site and found
this thread.
By the sound of this thread it is more complex than might be expected and I don't personally think that the benefit is worth the risk of
failure. If you did decide to use stainless then you would be well advised to source them from a highly reputable company and get a certificate which
you could then show the SVA inspector to satisfy him that this was a suitable type of fastener. (Note the points in the above thread about cheap
imitation fasteners with forged grading stamps...)
Craig.
Mark Allanson
| posted on 3/4/04 at 06:53 PM |
"Yes on the front wishbones Triumph used 7/16" unf -- a tiny bit bigger than 11mm
Lotus used 1/2" on the Elan wishbones but they were mounted in single shear"
They are actually 3/8, a little less than 10mm
| posted on 3/4/04 at 07:29 PM |
JCB bucket teeth are manganese steel, specially chosen as the abrasion it is subjected to causes surface hardening and is not relevant to anything in
car construction. They are soft until abrasion takes place and the material is not strong in tension like steel used for bolts.
Tblue
| posted on 3/4/04 at 11:16 PM |
As far as I can see (which isn't bad with my glasses on) I should imagine that the shear loads on the trailing arm bolts aren't that great
anyway, all the latitudinal force is taken by the Panhard rod, leaving the longitudinal forces to be absorbed by four 8mm bolts in double shear. I
mean, the popular donor RWD Escort only has one bolt each side of 3/8" diameter holding the axle in place, And I understand that that is holding
the spring too, but the forces on that longitudinally will be the same, if not more than in a Locost, due to the extra weight.
| posted on 5/4/04 at 06:06 AM |
What I was trying to say is not all stainless steels are the same -- it depends what type of steel and what you want it for and what you are
prepared to pay.
