Author: Subject: unequal length handbrake cables
blakep82
posted on 12/10/09 at 10:41 AM Reply With Quote
for various reasons, i need a handbrake system with 2 seperate cables. one will need to be about twice the length of the other.
am i going to come across problems with one stretching more than the other, and unbalanced braking efficiency etc? difficult to adjust etc?
I've got a rover handbrake lever with a compensator and fitment for 2 cables. the lever will go to the right of the seat, so the right rear wheel is only about 1.5m away, but the left rear is about 3m (1.5m across the back of the cab, and them 1.5m to the back axle)
or should i make them the same length and find a really long way round to route the 'short' one? i'd prefer to keep it neat and have them go direct to where they're going if posible
________________________
Mr Whippy
posted on 12/10/09 at 10:49 AM Reply With Quote
You could loop the cable that would be shorter round a pulley to increase the length. Pulleys are quite common in production cars and like you say it’s quite likely their will be an imbalance in the rear brakes when applied. Though tbh aren’t you meant to be stopped anyway before applying the handbrake?
Alternatively you could drill a hole further down on the handbrake link so the longer cable is pulled further than the short one to compensate for the extra stretching. Just how much this is I don't know.
I'd love to see why you have one cable longer than the other, are you doing something weird?
[Edited on 12/10/09 by Mr Whippy]
tegwin
Cant see an issue having two different length cables...
If each one has a sepperate threaded adjuster on the end you could re-tention them to get the best balance
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 12/10/09 at 10:57 AM Reply With Quote
Looking at the back end of your car, it just looks like a standard live axle, why is this needing something so different to a cortina handbrake setup etc?
blakep82
posted on 12/10/09 at 11:02 AM Reply With Quote
a very rough diagram.
whats the cortina set up? isn't that one cable with the handbrake in the middle?
its not a standard axle, but yes it is a live axle. its got sierra calipers. the back end of the truck is very long. i did buy a astra estate cable, and even that wasn't long enough for half of it to reach the back (but thats a single cable setup too)
Mr Whippy
posted on 12/10/09 at 11:13 AM Reply With Quote
if you used cables round pulleys you could do something like this? Rescued attachment 7handbrake.jpg
blakep82
posted on 12/10/09 at 11:24 AM Reply With Quote
hmm, yeah, could sort out something like that. i see you put all the pulleys in there, but if the cables all go through an inner cable they won't be needed will they? just need to secure it to the chassis, and theres plenty of tubes running around there
nitram38
posted on 12/10/09 at 11:31 AM Reply With Quote
Simple solution is to run a single cable from the handbrake to a yoke/pully which connects to the two equal length cables.
That way, all forces are equal.
MOT's will check for handbrake imbalance and cause a fail if you don't get this right!
Mr Whippy
posted on 12/10/09 at 11:47 AM Reply With Quote
no there's no inner cable, you have two separate cables, the pulley next to the handbrake is a double one. Its all rather like trailer brakes, have a look on the web for the parts they use and you'll see heaps of fittings you could adapt.
kj
posted on 12/10/09 at 12:41 PM Reply With Quote
What about a morris marina or ital cable set up like the diagram, or i have a pair of inner allegro cables i could let you have. Rescued attachment handbrak.JPG
Think about it, think about it again and then do it.
Mr Whippy
posted on 12/10/09 at 01:30 PM Reply With Quote
^ cool
posted on 12/10/09 at 03:22 PM Reply With Quote
Use a Morris Ital hanbrake cable complete -- no alterations required but you might need to rotate the brake back plates and re-drill them to clear your panhard rod or watts linkage.
posted on 12/10/09 at 07:48 PM Reply With Quote
I should also add the Ital/late Marina doesn't need anything fancy fittings made up --on the Ital it was just held to the axle with a single cable tie.
We used them as straight replacements for the Escort cable -- used to chuck away the solid pull rod and the horrid rubber flap hinge thingy. Doing this mod did wonders for the handbrake efficiency on one wheel on the MK1/MK2 Escort which was a very common MOT failure on these cars.
Ninehigh
posted on 12/10/09 at 09:44 PM Reply With Quote
Why not have the handbrake in the middle where it should be?
blakep82
posted on 13/10/09 at 12:12 AM Reply With Quote
can't do the ital/marina thing as the calipers are off a sierra, and the way they're mounted the cables need to pull forward (photos tomorrow) thanks for the offer though KJ
BT, its disc brakes on the rear, so no back plates for rotating or re-drilling
ninehigh, there are no chassis tubes on the top of the tunnel, and the tunnel is just 0.5mm sheet steel. so not stong enough. so it'll be bolted to the floor
I'll get some photos tomorrow that will hopefully explain it better.
though, if i've got long enough adjusters, i can't see that the difference in stretch in the cables will be more than about say 5mm?
you can maybe see in this photo why the tunnel can't have the lever mounted to it
[Edited on 13/10/09 by blakep82]
blakep82
posted on 14/10/09 at 12:27 PM Reply With Quote
ok, heres a photo of the calipers
and you see it has to pull to the front of the car.
as tegwin says tho, as long as i've got really long adjusters, it shouldn't be a problem
