smart51
| posted on 12/10/09 at 06:35 PM |
feathered tyre wear
After a recent track day with mostly left hand corners, the RHS rear tyre is worn in a feathered pattern but one I don't understand. The
central rib is worn on the outside and sharp on the inside but the outer tread blocks are worn on the rear and sharp at the front.
I always thought that tread blocks wore on the edge in the direction of travel. I must have been travelling in reverse then.
What does this wear pattern mean?
LBMEFM
| posted on 12/10/09 at 06:47 PM |
The tracking out of adjustment causes feathering and I would suggest that the centre section wear is caused by incorrect tyre pressures. During track
use the tyres will wear differently due to the high stress and temperatures
ashg
| posted on 12/10/09 at 07:14 PM |
its caused by the toe or camber being out. had it on my eurobox. think it was toe at a guess but it was quite a while ago
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Richard Quinn
| posted on 12/10/09 at 07:46 PM |
I had it on the front of a 4x4. It was 4 wheel aligned to check and found to be spot on. The dealer put it down to tyre flex and scrubbing due to it
being "an off-roader, not a bloody Subaru!!"
