New Topic New Reply
Author: Subject: Diff mounting
EasyJimbo
posted on 17/10/09 at 10:14 AM Reply With Quote
Diff mounting
Hi Guys
Do you know if the diff just mounts on the chassis direct or whether there are any rubber parts that need to mounted with them to house the diff etc?
thanks
James
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
Kriss
posted on 17/10/09 at 10:43 AM Reply With Quote
2 X M10 thread bar me thinks
Ben_Copeland
posted on 17/10/09 at 11:55 AM Reply With Quote
No rubber needed
Ben
Locost Map on Google Maps
Enter Your Details Here
Kriss
posted on 17/10/09 at 01:14 PM Reply With Quote
bare back you could say!
Staple balls
posted on 17/10/09 at 02:16 PM Reply With Quote
Either threaded bar or looong bolts, I'm pretty sure they're M12.
Best to put it in from below with someone to stick the bolts in/catch the diff when you drop it.
MikeR
posted on 17/10/09 at 04:04 PM Reply With Quote
Hardly anyone fits any rubber to the diff - although i've been told its a really good idea to cushion the diff to stock the shock foces being transmitted to the chassis.
big-vee-twin
posted on 17/10/09 at 04:55 PM Reply With Quote
m12 x 208mm long high tensile bolts
http://www.triangleltd.com
mad-butcher
posted on 19/10/09 at 08:40 AM Reply With Quote
or the easy way, long bolt on bottom, 2 allen bolts in the top, heads inside nuts on outside, the reason.....you'll find out if you use 2 long bolts.
tony
Staple balls
posted on 20/10/09 at 04:38 AM Reply With Quote
So, what is the reason? Never had a problem with the top bolt, needs a bit of a wiggle to get it past the frame, but nothing terrible.
EasyJimbo
posted on 20/10/09 at 07:09 AM Reply With Quote
Used threaded bolt in the end and the top one was a bit of a challenge wiggling it past the chassis but was fine after that.
thanks for all your help
j
New Topic New Reply
