Author: Subject: bearing identification
aka Keith
posted on 18/10/09 at 07:43 AM Reply With Quote
I have now eventually got my rear wheel bearings out and have a code stamped on them.
SKF BT1B 328053
I have been googling most morning with little success. I want to identify which type of ford sierra these came off - as it makes ordering repalcements so much bloody easier.
Anyone any ideas?
Craig
designer
posted on 18/10/09 at 08:13 AM Reply With Quote
If ever you want to replace a bearing, take it to a factors and tell them you want the equivelant.
All bearings are standard, the only difference being the manufacturers part number.
Much cheaper to do it this way.
t16turbotone
posted on 18/10/09 at 08:21 AM Reply With Quote
maybe this will help...there seems to be three different bearings for the sierra/granny models
1. QWB 533 RH
QWB 532 LH
same bearing just different part number for RH nut or LH nut.
2. QWB 527
QWB 528
3. QWB 567..?
tech info here
http://www.quinton-hazell.de/downloads/QH12/101-107%20Info.pdf
