Author: Subject: Type 3 gearbox
Rik178m@hotmail.com
posted on 19/10/09 at 06:40 PM Reply With Quote
Type 3 gearbox
Hi all, cant find any info on a ford type 3 gearbox! My mate had a mexico 4speed in his westfield so while looking for one of those (2000E is it?) I found the above. I already have a type 9 5speed but I'm open to options.
Would the type 3 be any good? Is it close ratio like the mexico box? I'm not after a really high top end from my zetec.
Already googled with not much of a result.
thefreak
posted on 19/10/09 at 06:44 PM Reply With Quote
Is it not the one I sent you a pic of?
Rik178m@hotmail.com
posted on 19/10/09 at 06:47 PM Reply With Quote
It is indeed. I must of miss read your thread as I thought it was meant to be a type 9. Now I'm abit lost
Had a look in the burton power catalog and I'm non the wiser as to if it's the one I'm after.
Ideally I'd like to find a mexico close ratio box.
Werner Van Loock
posted on 19/10/09 at 07:14 PM Reply With Quote
maybe this helps:
http://www.zetecinside.com/xr2/gearbox.shtml
http://www.clubstylus.be
Rik178m@hotmail.com
posted on 19/10/09 at 07:18 PM Reply With Quote
Thanks mate but thats just the same thing as in the burton catalog.
rallyingden
posted on 19/10/09 at 08:01 PM Reply With Quote
Is it like one of these ?
edit for Better pic
RD
gerboxes
gerboxes
[Edited on 19/10/09 by rallyingden]
Rik178m@hotmail.com
posted on 19/10/09 at 08:10 PM Reply With Quote
yes mate
rallyingden
posted on 19/10/09 at 08:31 PM Reply With Quote
Which one ?
The one on the right is what I have fitted and I managed to identify it as a type 3 gearbox.
I have a link somewhere possibly at work I will try and dig it out for you.
RD
thefreak
posted on 19/10/09 at 08:33 PM Reply With Quote
Is there any way of telling? As I've got a 4 speed box sat in the garage taking up space and I want rid
rallyingden
posted on 19/10/09 at 08:49 PM Reply With Quote
Thefreak...
The Zetec inside link ^^^ above ^^^ is good for identifying which box you have
RD
Rik178m@hotmail.com
Sorry only saw 1 at a quick glance. Its the box on the right with the bellhousing from the left.
Stewart do you mind me posting the pics mate?
thefreak
posted on 19/10/09 at 09:04 PM Reply With Quote
Not at all... saves me doing it
And I've got a red bell housing like the one on the left if you wanted that too. keep tripping over it in the conservatory
[Edited on 19/10/09 by thefreak]
Rik178m@hotmail.com
posted on 19/10/09 at 09:10 PM Reply With Quote
rallyingden
posted on 19/10/09 at 09:11 PM Reply With Quote
Defo a type 3
What exactly do you want to know ?
RD
Rik178m@hotmail.com
posted on 19/10/09 at 09:15 PM Reply With Quote
Am I going to be better off using a type 3 4speed or type 9 5speed witha a 2ltr zetec?
Not sure of the diff ratio i have yet.
I was looking for a close ratio 4speed mexico box as recommended by a mate but is the type 3 a good alternative?
rallyingden
posted on 19/10/09 at 09:19 PM Reply With Quote
I am no expert on Zetec's but from reading past posts I suspect the type 9 would be more suitable. It does however depend on your final drive ratio and what YOU want from the car.
Sorry if this does not answer your question
RD
Rik178m@hotmail.com
posted on 19/10/09 at 09:21 PM Reply With Quote
It does mate. I'll be keeping the type 9 for when I need a higher top end. Was thinking about a 4speed for the tight and twisties. but not sure of the ratios on the type 3. Is it close ratio?
frankie boy
posted on 19/10/09 at 09:29 PM Reply With Quote
Hi
Did just leve a post on the haynes. But be carefull with the clutch are as it comes out at 90 degrees with the box and will hit the transmission tunnel. The type nine is at around 45 degrees and only just clears.
