phelpsa
posted on 5/4/04 at 06:10 PM |
Nylocks on Cortina Uprights
I am using nylocks on my front cortina stub axles as I couldn't find a decent set of castles. They work on a sierra, why not a cortina.
Adam
posted on 5/4/04 at 06:51 PM |
Just check that the thread goes through the lock. Some joints seem to have shorter threads than others, don't know why but I have seen cases
where the nuts have had to be cut down.
Glan Noye
posted on 5/4/04 at 08:15 PM |
I dont think this is an option.Dont the sierras have a rolling spindle?
DavidM
posted on 5/4/04 at 09:37 PM |
My Cortina bottom balljoints and transit tops came with nylocks. Work fine.
If the thread's long enough for a castellated nut, I'd have thought it must be long enough for a nylock.
IMO
Glan Noye
posted on 5/4/04 at 10:37 PM |
Did you mean the nuts on the spindles or balljoints?Glan.By the way did you find any wheels?
phelpsa
posted on 6/4/04 at 07:28 AM |
I am talking about on the spindles. I think I have just about secured some wheels.
Adam
flyingkiwi
posted on 6/4/04 at 08:58 AM |
Just rebuild my cortina uprights and mine didn't have castellated nut's either, just normal nuts with a locking cover that held the split
pin, so I'm guessing a locknut should be fine, with a dabble of locktite just to be sure.
It Runs!!!!! Bring on the SVA!
posted on 6/4/04 at 09:14 AM |
Sorry I read it wrong!!
Sierra is a different setup and uses a left hand thread on the nearside to counteract rotational loosening. My hub nuts (Cortina) have a castellated
cover that the split pin engages, not the nut itself.
