Author: Subject: Master Cylinder Repair Kit
Daddylonglegs
posted on 22/10/09 at 08:39 AM Reply With Quote
Hi all.
Just got myself a second-hand Mk Fiesta MC and need to get a repair kit for it.
I make the bore to be 20.4mm and I have put a couple of pictures below.
There is no plastic band around it so I cannot use that to find the parts. Does anyone know what kit I will need?
Thanks.
JB
Fiesta MC-1
Fiesta MC-1
Fiesta MC-2
Fiesta MC-2
Mr Whippy
posted on 22/10/09 at 08:43 AM Reply With Quote
There will be part numbers cast into the alloy pistons, simply type them into google
Have you checked the bore inside? If it’s too worn there will be a noticeable step about halfway down, if it has I’d be careful about using it as this can sometimes flip the seal and cause the brakes to fail, as I’ve found out myself.
[Edited on 22/10/09 by Mr Whippy]
paul the 6th
posted on 22/10/09 at 08:44 AM Reply With Quote
hi mate,
I've just ordered a caliper overhaul kit from bigg red - http://www.biggred.co.uk/cylinderrepairshop.html - they have an "Master Cylinder Repair" section...
You'll have to have a look through the Catalogue to find your model and then order the right kit from the first link.... Failing that, send them a quick email with picture included and they should be able to advise which kit you need (they did for my calipers)
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
theconrodkid
posted on 22/10/09 at 08:49 AM Reply With Quote
new cylinders are soooooo cheap from the likes of brakes international,is it worth the risk?
who cares who wins
pass the pork pies
Daddylonglegs
posted on 22/10/09 at 09:04 AM Reply With Quote
What would you recommend for M16 fronts (solid discs) and 9" rear drums?
Thanks for the replies guys. I definitely need to go down the tandem MC route or I'll have to do some major re-work/spending
whitestu
posted on 22/10/09 at 09:42 AM Reply With Quote
I've just bought a Fiat 124 non servo cylinder from Brakes International following Conrod's recommendation.
Link to Brakes International
It was about £30 delivered. Not fitted yet but should be in the next couple of weeks.
I'm running standard Sierra disks and drums.
Stu
[Edited on 22/10/09 by whitestu]
Mr Whippy
posted on 22/10/09 at 09:43 AM Reply With Quote
a cortina m/s should be fine for that as that were the brakes fitted to them. I'd give you a link but the supplier I used has had their web page account suspended!
