Author: Subject: Play in english diff
twybrow
posted on 26/10/09 at 09:04 PM Reply With Quote
I posted a couple of days ago (here) about a funny noise from the propshaft/output shaft, well I have done a bit more investigating....
I found that both of my lower trailing arm bolts were not tight, which meant the axle could rotate when under load (eg by rocking gently when in gear).
I also noticed my diff (escort rs live axle) input flange moves sideways 2-3mm if you push it sideways. Does this sound normal?
posted on 26/10/09 at 09:37 PM Reply With Quote
no. pretty sure that is not right - the output flange sits in a bearing so there should be no side to side play.
looks like you are gonna have to take a peek
posted on 26/10/09 at 09:38 PM Reply With Quote
No, the pinion bearing is supposed to be pre-loaded so there should be no play here. Probably the crush tube has relaxed a bit over time and loosened everything up.
twybrow
posted on 26/10/09 at 10:13 PM Reply With Quote
Oh well... It looks like the axle rebuild + lsd is next on the cards (it was supposed to be a winter thing!)....
mangogrooveworkshop
posted on 26/10/09 at 11:15 PM Reply With Quote
Is it just me .......but in your avatar the car is very high off the ground at the front
westf27
posted on 26/10/09 at 11:23 PM Reply With Quote
look at the bottom bone,bump steer going on ?
555
twybrow
posted on 27/10/09 at 12:02 AM Reply With Quote
And no number plates too!!
Yeah, it was on stilts on the way to SVA. Now all suspension sorted my Procomp. I need a new avatar pic!
speedyxjs
posted on 27/10/09 at 08:11 AM Reply With Quote
Id expect mine is going to look like that as the sump is very low.
