Author: Subject: Front uprights - best finish ??
fesycresy
posted on 28/10/09 at 05:36 PM Reply With Quote
Right then, what's the best finish for uprights ?
I've finished uprights in the past with red oxide and Hammerite and it didn't last long, I had to keep touching them up. Halfords satin seemed better than Hammerite.
Perhaps normal paint (as opposed to Hammerite) over red oxide would be better ?
I've a set of Cortina uprights that have been blasted and primered, however some surface rust has starting to get through.
Brake caliper paint has been recommended, but I can only see it in red/blue/yellow colours.
Any suggestion ?
austin man
posted on 28/10/09 at 05:40 PM Reply With Quote
ensure you thoroughly remove all rust then use etch primer or a zinc rich primer followed by Hammerite or similar Ronseal also do one.
omega0684
posted on 28/10/09 at 06:15 PM Reply With Quote
metal primer and hammerite!
fesycresy
posted on 28/10/09 at 06:23 PM Reply With Quote
Perhaps I used the wrong primer ?
Red oxide gave a cracking finish but the paint didn't seem to take that well.
How have yours survived omega, did you find the hammerite brittle ?
theconrodkid
posted on 28/10/09 at 07:13 PM Reply With Quote
por 15,it,s expensive but when i tried to get some off my chassis to weld a bracket on,i had to resort to the angry grinder
who cares who wins
pass the pork pies
SALAD
posted on 28/10/09 at 07:30 PM Reply With Quote
Brake fluid is a good one for removing POR15
Jon Ison
posted on 28/10/09 at 07:33 PM Reply With Quote
I had mine powder coated 2 years back, look same today they did then.
DRC INDY 7
posted on 28/10/09 at 08:30 PM Reply With Quote
Ditto
Puddle Dodgers Club
Steve Hignett
posted on 28/10/09 at 11:08 PM Reply With Quote
Black Caliper Paint on ebay...
Loads if you search for "Black Caliper Paint" in Google also
flak monkey
posted on 29/10/09 at 07:50 AM Reply With Quote
Several thick coats of hammerite on mine and other than the odd bump where I took them off the other week they are as good as they were when i put them on.
Sera
http://www.motosera.com
mad4x4
posted on 29/10/09 at 01:06 PM Reply With Quote
Originally posted by DRC INDY 7
Ditto
Ditto
Scot's do it better in Kilts.
