Author: Subject: Swap a Diff anybody??
Chippy
posted on 28/10/09 at 11:51 PM Reply With Quote
Hi, I have a very good 3.62 open diff, it has been checked for the correct backlash, and is well within Fords spec. I am willing to swap this for a knackered diff that has the bearing carriers in good condition, any ratio. I am overhauling a diff in which the bearing carriers have been mullered, and while I could take the bearing carriers from the 3.62, it seems a bloody shame to ruin a perfectly good diff. If you want to pay the P & P on both you could get a good diff for just the postage. I think that Parcels 2 Go will do it for about £8.50 ish, so for £17 ish you would get a good diff. Anybody interested? If not I will have to break the 3.62, Cheers Ray
A1
posted on 29/10/09 at 01:22 AM Reply With Quote
yes...ive got a 3.92 limited slip... is there much handling difference between the two?
craig1410
posted on 29/10/09 at 12:44 PM Reply With Quote
Is it a 7" diff or 7.5"? I have a good 3.92:1 7.5" diff which I'm looking to change for a 3.62 or lower ratio.
Craig.
Chippy
posted on 29/10/09 at 04:30 PM Reply With Quote
A1 the 3.62 will give you less revs for the same speed, so a bit more economical. I would point out though that the one I have is NOT LSD, it's an open diff.
Craig, it's a 7" sorry, although your bearing carriers will fit it.
Cheers Ray
mangogrooveworkshop
posted on 29/10/09 at 06:26 PM Reply With Quote
we will go with this deal
Chippy
posted on 29/10/09 at 10:34 PM Reply With Quote
mangogrooveworkshop
You have U2U. Cheers Ray
