thepest
| posted on 1/11/09 at 03:16 PM |
Compomotive spit rims leaking
Asd the title says... do I need to dismantle the rims and apply sealer between outer and inners or can I get away with just applying sealer without
taking apart the rims?
If I do take them apart anyone know what torque the bolts need to be tightened to?
Chippy
| posted on 1/11/09 at 04:56 PM |
May be wrong, but don't you normaly have to use tubes with split rims. Cheers Ray
thunderace
| posted on 1/11/09 at 05:37 PM |
you can just seal them by removing the old bits from around the inside with a good wire brush then resealing them with a good silicone done it before
with my bbs wheels but there is a cheeper and easyer way.
buy this from ebay.
Item number: 220493087530
Item number: 160374190083
Item number: 250512420915
i have used it on my bbs all wheels and it worked fine.
i use this one
Item number: 370274532245
thepest
| posted on 2/11/09 at 08:32 AM |
Thanks Guys, I'll give the sealer a go. I never knew about the tubes in split rims Chippy, I thought that tubes were a no-no in high performance
tyres & rims.
thepest
| posted on 2/11/09 at 08:37 AM |
Interesting sealer thunderace, I'll read up on them an prob give them a go.
